Latest post Fri, Apr 11 2008 4:30 AM by joelrmorgan. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Apr 10 2008 12:47 AM
    • joelrmorgan
    • Gresham, Oregon
    • Posts 126
    • Points 1,625
    Importing PSD files error- "not saved with a composite image"
    Hi, friends.  With no new changes to my system or settings in either Avid or Photoshop that I remember, I am suddenly unable to import full screen layered PSD files - Something I've done countless times before.  Each image in Avid shows up with a black box on a white background with the message (in 4 languages), "This layered Photoshop file was not saved with a composite image."  I can save the files as PNG files (and probably other formats) and they import fine, but I'd rather not go through that process.  Any ideas what I'm doing wrong?
    Many thanks.
    - Dell Precision 670 - Dual Xeon processors (2.8) - 2 gigs of Ram - nVidia 1400 (driver 7.7.1.8) - Creative SB X-Fi sound card - 120 Gig boot hard... [view my complete system specs]
  • Thu, Apr 10 2008 3:27 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,632
    • Points 160,425
      Moderator: MCA Mac
    Re: Importing PSD files error- "not saved with a composite image"
    Were the Photoshop files prepared in the same way/by the same person as has always been done at your facility or are these files different somehow?
  • Thu, Apr 10 2008 4:24 PM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 126
    • Points 1,625
    I'm a one man shop, and do it all myself.  And, I made these graphics the same as I always have.  Something's certainly different, but I don't know what.  My searches here and elsewhere have been futile.
    And it was a pain to convert everything the PNG file.  First, unless they are flattened, they import as alpha files, even if they are full screen.  I don't remember this happening before either.  Thank goodness for "actions" in Photoshop allowing me to flatten and save each of the many files quickly with a simple single click of the mouse.
  • Fri, Apr 11 2008 1:27 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 126
    • Points 1,625
     Any help from anybody?
  • Fri, Apr 11 2008 1:38 AM In reply to
    Do you have a vector shape mask layer?
    Have you left it as a CMYK image rather than RGB?
  • Fri, Apr 11 2008 1:49 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,184
    • Points 36,535
    Firstly, as Andrew suggests, I would check whether you have vector layers (text, shapes or similar) that are not rasterised, and that you are truly in 8-bit RGB.  If not you will need to re-export your PSD file with the correct settings.
    joelrmorgan:
    Even if a graphic has an alpha channel you can change the import settings on Avid to ignore it.  It will then come in as a flattened graphic.
    MC 3.0 - Gigabyte GA-X38-DQ6 mobo - Intel core 2 Extreme Q6850 3 GHz - nVidia Quadro 1700 - 4 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro... [view my complete system specs]
  • Fri, Apr 11 2008 3:08 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 126
    • Points 1,625
    Andrew, a full screen background (the only layer) doesn't even import correctly.  However, several include text that isn't rasterized.  That's never been a problem before, either.  Similar graphics with unrasterized text and shapes have always imported perfectly until yesterday.  And, no, everything is RGB/8.
    Jwrl, yeah I could change the defaults in AXP, but I'd rather simply solve this problem and work like I used to.
    Thanks for the thoughts and suggestions.  Anyone else?
  • Fri, Apr 11 2008 3:50 AM In reply to
    joelrmorgan:
    I seem to remember that Photoshop here used to occassionaly pop up a message when saving that you had to do something to insure maximum compatability. Cannot remember the details sorry
  • Fri, Apr 11 2008 4:30 AM In reply to
    • joelrmorgan
    • Gresham, Oregon
    • Posts 126
    • Points 1,625
    I think that was referring to PSD files from 4.0 (or abouts there) and CS.  I am using CS with full compatibility, and have been for some time.  Hence, that's certainly not the problem.  But nice suggestion.  Keep it up!
