Latest post Mon, Apr 28 2008 8:56 AM by hbrock. 3 replies.
  • Wed, Apr 9 2008 11:13 AM
    1080P AXP to Logic Pro 8
    Hi All
    Any helpful tips to export from AXP 5.8 to Logic Pro 8 I've tried .mov and m4v and my music composer cant read it! Can I do omf's
    Iain
    Dual 2.7 OSX 10.5.2 6 Gig RAM 3 Tbite AXP 5.8 [view my complete system specs]
  • Sat, Apr 12 2008 7:31 PM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,736
    • Points 31,295
    Re: 1080P AXP to Logic Pro 8
    Depends on what you've got....
    You can convert the audio to OMF and then export it.  As far as the picture goes, the .mov or m4v are HD video formats.  If your composer is expecting SD video you'll need to export to a SD QuickTime format.  Check with the composer to see what format(s) is desirable.
    MacPro, MacBook Pro and a Cube. The Cube doesn't do much but it looks cool. [view my complete system specs]
  • Mon, Apr 28 2008 8:05 AM In reply to
    What is wierd in 1080 AXP project is that you cant do omf?????
    what is that about?
  • Mon, Apr 28 2008 8:56 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 2,736
    • Points 31,295
    HD projects use MXF media.  You have to first convert the audio to OMF if you want to do a OMF export.
