Quick version of question: How do you backup a project -- including all the media -- to some removable external storage? Long version of question: Our production department had been using local storage as well as Isis storage (but no Interplay login) for a year. Things were working ok. When they'd finish up with a client, the project with all of the captured media would be moved into a seperate folder on an external USB drive using MDV Avid Media Mover. The producer loved this, as it worked, was simple, was easy to get all the stuff from a single project, and was easy to restore it. They've finally decided to join the rest of the staff and embrace Interplay. This means the the PMR files are no longer used on Isis (and have been deleted). The MDV Media Mover program uses the PMR file to determine what's what in the various media folders, so that method is sunk. It doesn't know anything about dealing with the Interplay database. I've looked at the consolidate function, but it doesn't seem straightforward, and I'm having difficulty understanding how it might be used in such a workflow. We don't want to consolidate the sequence, only the media, as we want to keep all of it (not just the media used in the sequence). And even if we did go that route, how does one bring the project back into the system? We're using Avid NewsCutter Adrenalines, version 6.7.7. I've done searches on CreativeCOW, Avid's forums, and the NewsCutter help files, trying to find something(the concept seems very basic, so we imagine plenty of people would have wanted and needed to do this). Thanks Pat Furrie WESH/WKCF, Orlando
Hi Pat: what about setting the Local Media Indexer to scan the local storage, aka USB drive, then consolidate all the media and then, if you need it, consolidate back to the ISIS again?
Take a look at the Interplay Best Practices pdf and look the Configuring the Media Indexer chapter.
Regards
Felipe Gonzalez
ACSR Interplay
Avid Latin America
El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
