Latest post Wed, Apr 9 2008 8:07 AM by indigospin. 3 replies.
  • Sat, Apr 5 2008 1:34 PM
    • yuval26
    • Joined on Tue, Mar 25 2008
    • Posts 3
    • Points 45
    Problem: video always play in black and white
    Any captured material I play inside avid - is always displayed in black and white. When the video is paused and when advancing frames by frames - it shows the colors normally.
    (Trying to search for posts from people who had a similar problem always yields results with questions about how to make a clip black and white... :( )
    I'm running 5.0 on Windows XP SP2.
    My video card is NVidia GeForce 8800GT.
    The driver version is the latest: 6.14.11.6921
    I cannot "rollback" to older driver versions that are more "supported" by Avid (like 77.18 or 77.77) - since these only support older cards (6 & 7 series) - when I try to run their setup - it tells me it can't find the right hardware.
    I've read and heard from people - that the 8800 should work fine.
    Buying another "older" card - is currently not an option.
    Any advices will be appreciated...!
    - Yuval
    Intel Core2 Quad CPU Q6600 2.40Ghz 2GB of RAM NVidia GeForce 8800GT Windows XP SP2 Avid Xpress Pro 5.0 [view my complete system specs]
    Filed under: , , , , ,
  • Sat, Apr 5 2008 8:46 PM In reply to
    • jasonsaro
    • Philadelphia
    • Posts 504
    • Points 6,125
    Re: Problem: video always play in black and white
    I would try running the latest driver from NVidia, 91.85. I have a Geforce FX5200 and its great with it.  MC 2.8.1.
    1 MC DX - 3.5.4 -- 1 MCA DNxcell ver. 3.1.2 -- 3 MCA's ver. 2.8.4 -- 1 MC Meridian Composer 1000 Ver 12.1.1 -- 3 MC Mojo 2.8.4 -- 1 Xpress Pro Mojo... [view my complete system specs]
    "What we want is a smashing theme of mythic grandeur" - Stanley Kubrick Favorite Avid Term "JBOD" - Just a Bunch Of Disks _______________ Jason Saro SR. Avid Editor / Unity Admin. - Nancy Glass Productions jason@nancyglassproductions.com
  • Sat, Apr 5 2008 10:18 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,836
    • Points 80,755
    Avid version 5 and that card/driver... do not waste your time. Get up to 5.8 or get another card and driver.
    Menno
    MC 3.5.1 Test-Intel Core2Duo 6800,GTS8800 Nvidia,Realtek HD, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Apr 9 2008 8:07 AM In reply to
    • indigospin
    • Lubbock, Texas, USA
    • Posts 458
    • Points 5,095
     seriously, you can fudge on a number of Avid's "certified" specs with relative success... but when it comes to video card & driver issues, you're moving onto the VERY thin ice where avid is Most sensitive & finicky.  i myself used to try to get by, but with the 5.x releases of AXP, i learned the hard way you're almost guaranteed some kind of headache if you don't fall in line in this one area.
    my advice, save yourself the inevitable trouble & use a certified card & driver.  check my specs & note my video card & driver.  it's one of the least expensive certified cards & it works like a charm.
    good luck!
    shane
    ASUS P6T Delux MOBO, Intel core i7 2.93GHz, 3 GB RAM, Windows XP Pro SP3, NVIDIA QuadroFX3500 (driver 169.47), 4 TB of storage on 6 SATA drives... [view my complete system specs]
    staffer: "How do you go without sleep for so long?"  me: "Not nearly as well as I used to."
    indigospin.com
      <--Click to check out our online portfolio of more than 20 sample videos!
