Latest post Mon, Apr 21 2008 11:30 PM by Rob Stowell. 7 replies.
  • Fri, Apr 4 2008 11:04 PM
    • JPJ
    • Joined on Fri, Apr 4 2008
    • Posts 4
    • Points 60
    Import from .MOV audio question.
    New to Free DV. . .
    I am importing video/audio from Quicktime .mov file to the bin.  When I preview the resulting clip, the audio is just white noise at full scale amplitude.
    Just about smoked my speakers the first time around.  I have tried experimenting with some of the sample rate/bit depth conversion options with no change.
    Any suggestions?
    Thanks!
    JPJ
    AMD x64 Dual Core 2.10Mhz, 2G RAM, nVidia 8500 GT, Windows XP Pro
  • Fri, Apr 4 2008 11:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,697
    • Points 161,360
      Moderator: MCA Mac
    Re: Import from .MOV audio question.
    You need to tell us where the QT came from and what codec the Audio is using. What sample rate is the QT and what is your project audio set to?
    Also, what version of QT?
  • Fri, Apr 4 2008 11:46 PM In reply to
    • JPJ
    • Posts 4
    • Points 60
     Sorry,
    QT file came from a Minolta digital camera.  Not sure of the audio codec but the file info states "Compression: None" (audio track)
    Bit depth of source audio is 16, Sample rate is 7.832Khz.
    Project audio is set to 16Bit/48K and under Import Settings/Audio "Convert source sample rate to project sample rate" is selected.
    The installed version of Quicktime is 7.3
    Thanks. . .
  • Sat, Apr 5 2008 12:45 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,697
    • Points 161,360
      Moderator: MCA Mac
    I think the problem here is the sample rate. You need a sample rate of either 32khz, 44.1 or 48.
    I've never seen a file with 7.8 so I'm guessing the Avid may have a problem converting that.
  • Mon, Apr 7 2008 1:20 PM In reply to
    • camoscato
    • Posts 4,435
    • Points 52,970
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    JPJ:
    Try uninstalling QT 7.3 and install 6.5.2 instead.  QT 7.3 isn't qualified for FreeDV.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Mon, Apr 7 2008 1:25 PM In reply to
    • JPJ
    • Posts 4
    • Points 60
    Thanks Carl, I'll check that out.
    Regards. . .
  • Mon, Apr 7 2008 1:28 PM In reply to
    • JPJ
    • Posts 4
    • Points 60
    BLKDOG:
     Hey, Thanks. Sounds like you could be right, although I have several other editors that open these Quicktime movies without problems(not to imply that Avid behaviour is the same. . .)
    I may end up converting to avi and importing to Avid.
    Cheers
    JPJ
  • Mon, Apr 21 2008 11:30 PM In reply to
    • Rob Stowell
    • Christchurch, New Zealand
    • Posts 335
    • Points 3,675
     I wouldn't be too hasty about rolling back to QT 6.5.2
    I'm running xpro 4.6 and I've stuck with that, 'ocs I can't afford to lose projects at work!
    But running free dv on a range of machines, and quicktime 7 seems fine. (Not sure about 7.3 though.) And it has advantages, esp there's now an mpg4 export option, and it will import mgp4 movs without just showing white for video (as well as white noise audio, haha.)
    7.8 does seem an odd... (very very low) sample rate, and I think it is your problem: I'd try converting that to one of the above mentioned first. avis are ok, but movs are generally a bit better (and import faster) in avid.
    hp xw3200 1 gig ram 160gig + 200 gig sata video storage, x-pro 4.6 [view my complete system specs]
    kia ora- Rob
