Latest post Fri, May 30 2008 8:39 AM by jimmyt72. 7 replies.
  • Thu, Apr 3 2008 2:43 PM
    • erik auli
    • Joined on Thu, Apr 3 2008
    • Posts 2
    • Points 30
    FCP 6.0.2 on Unity 5.0.1 , connection to render files lost
    Is anyone out there working with Final Cut Pro off an Avid Unity Media Network? I'm having an issue with maintaining the media's connection to their render files, mostly when working with titles and effects. I'll render titles or effects in a sequence and they will play back fine as long as I stay within FCP. Once I switch over to the finder or another application, when i return to Final Cut the connections to the render files are lost. The render files still exist on the Unity workspace, but I need to then manually reconnect each render file which is extremely time consuming. Storing the render files on a local hard drive solves the problem, but I really don't want to have to do that. I know other people have experienced these same problems, but I haven't found any answers on the forums. Does anyone have any suggestions or solutions I haven't considered? I'm running FCP 6.0.2 and Avid Unity 5.0.1 on an 8-core 3ghz mac pro, OSX 10.4.11, w/ an AJA IO HD. Let me know, thanks. -Erik Auli
  • Thu, Apr 3 2008 3:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 12,202
    • Points 154,850
      Moderator: MCA Mac
    Re: FCP 6.0.2 on Unity 5.0.1 , connection to render files lost
    Well, we'll skip the obvious observations about teaching you to use FCP on an Avid forum.... Smile
    To what do you have your scratch and render disk set in FCP? I will say this, FCP does not do well on Unity. It sees the workspaces simply as mounted volumes and loses connection to them often.
  • Thu, Apr 3 2008 4:10 PM In reply to
    • erik auli
    • Posts 2
    • Points 30
    The scratch and render disk are set to the project workspace on the unity. I'm aware that changing the render files scratch disk to a local drive solves the issue, but I'm trying to see if there's anyway around that. I'm looking to work exclusively off of the unity if thats possible. It seems like its just a software issue with FCP that hopefully will be addressed in the next update, but wanted to see if anyone has found an alternative solution until that happens.
  • Thu, Apr 3 2008 4:43 PM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 389
    • Points 4,775
    We bought an XSAN for the reasons BLKDOG states. They have brought out XSAN 2 but sadly you can't update or part exchange XSAN 1 for.  However this does leave the  first XSAN version a lot cheaper than it was.
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
    Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke
  • Mon, Apr 7 2008 4:41 AM In reply to
    Whoa, Whoa, Whoa. I thought the whole point with the "Open" archetecture of 5.x was so that other Applications work on Unity. AE, FCP etc.
    Avid needs to re-hire their AE's.  It was such a bad move to become a marketing, stock market driven company in such a small, focused market as Post Production.
    brent
  • Thu, May 15 2008 8:55 PM In reply to
    Avid has pretty much abandoned the Open Storage Initiative. We've done a lot of FCP on Unity testing and the quick answer is that the render issue is an FCP bug, fixed in 6.0.3 FCP 6.0.2 had the "copy sequence render" fix, but 6.0.3 seems to now retain renders on Unity 5.0.1 Hope this helps, and "Hi" Brent, how are things at Digital Core? Sig Knapstad ACSR Elite Cutting Edge
  • Thu, May 29 2008 9:40 PM In reply to
    But wait, there is more....
    Turns out we have found that some renders are still not retained. If the file is Pro Res with an Alpha Channel then it won't keep the render if sent to Unity. It will retain the render if sent to local storage. I believe Pro Res doesn't have Alpha support, but it is still odd that it will work to local, but not to Unity. Other than this, all other renders (ie, Animation codec with Alpha) seem to work.
    More later,
    Cheers,
    Sig Knapstad
    ACSR Elite
    Cutting Edge
  • Fri, May 30 2008 8:39 AM In reply to
    • jimmyt72
    • Posts 68
    • Points 740
     Are you using the updated Unity 5.02 connection manager on your Macs?
