Latest post Wed, Apr 2 2008 11:49 PM by daktulus. 7 replies.
  • Wed, Apr 2 2008 6:52 PM
    • daktulus
    • Posts 376
    • Points 5,035
    How do I control Betacam deck with laptop? Where is Com Port on laptop?
    Where is Com Port on Dell Laptop? How do I control Betacam deck? I used to capture with my workstation through COM1 and Addenda Rosetta stone adapter. How do I control via Dell M90 laptop?
    Dell650, 2.8Ghz, 3 GB RAM, FX500, 5 SCSI HDDs, Mojo. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm Media Composer 3.0 [view my complete system specs]
  • Wed, Apr 2 2008 7:09 PM In reply to
    • Reanimated
    • Joined on Mon, Jan 16 2006
    • Stockholm, Sweden
    • Posts 57
    • Points 645
    Re: How do I control Betacam deck with laptop? Where is Com Port on laptop?
    I use the cheapest usb-com adapter i could find..... and haven't had any problems
    MC 3, Nitris DX, HP XW8600, Win Vista 64bit, Avid VideoRaid RTR320, MC 2,8,Mojo SDI, HP nw9440 2GB, Windows XP Pro SP2, Aten usb to rs-232thing Homebuilt... [view my complete system specs]
  • Wed, Apr 2 2008 7:38 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    did you ever try to control a deck with it? Does Avid recognize the USB connection as COM port (in deck configuration)?
  • Wed, Apr 2 2008 8:32 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    if the USB to 422 works as it should Avid should only see a com port .. after that it is up to the relatively simple protocol of controlling.
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Wed, Apr 2 2008 9:17 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    the addenda rosetta stone works with the COM1 port on the workstation - so I just adapt from the COM to USB with any simple USB COM adapter and it works?
  • Wed, Apr 2 2008 10:52 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 984
    • Points 11,640
     Addenda sells a USB-422 adapter.  I have a Precision M90 and use it all the time to control beta decks.  It is worth it's weight in gold.
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Wed, Apr 2 2008 11:15 PM In reply to
    I got a Belkin adapter from Frys, for less than $20, and it worked just fine.
    Avid 5.7.5 Intel duo core @2.33 Asus mobo 4 gigs DDR2 800 (3 gig patch) 2 Terrabite Storage in 4 SATA2 300 drives (no raid yet, but will make 2 drives... [view my complete system specs]
  • Wed, Apr 2 2008 11:49 PM In reply to
    • daktulus
    • Posts 376
    • Points 5,035
    can I use the old COM Addenda adapter with a simple COM -> USB connector or do I need to change the signal with a special adapter from RS422 to USB again? I have to capture tomorrow and have no time to order... I guess a simple COM (the one that looks like VGA) to USB can be bought in a normal electronics store. (IF the signal doesn´t need to be changed again)
