Latest post Thu, Apr 3 2008 12:44 PM by Jailer. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Apr 2 2008 3:59 PM
    • Jailer
    • Medellín, Colombia
    • Posts 66
    • Points 830
    CM_NO_TRACKS_FOUND
     Hi everybody.
    I have a big problem. When I create the Media Tool Xpress Pro 5.7.2 show me the following message: CM_NO_TRACKS_FOUND and error ocurred loading database. H:/Avid MediaFiles/MXF/1, it don´t show me media files of all projects. I already erased the msm files and continue the problem.
    Help me please!
    Thanks you
    Dell Precision 650, Xeon 2.8, 1.5 GB ram, Nvidia Quadro FX 500, disco de sistema 40GB, Disco para gráficos... [view my complete system specs]
  • Wed, Apr 2 2008 4:04 PM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 443
    • Points 5,365
    Re: CM_NO_TRACKS_FOUND
     Although you delted them did they actually rebuild is there a chance when you look in the folder there might only be 1 database ? Don't take this the wrong way but is your drive full ?
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
  • Wed, Apr 2 2008 4:18 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
    In the Avid Media Files there are three foldres, MXF 1, MXF 2 and MXF 3, 1 and 2 have media, 3 only has one file with extension in .pmr
  • Wed, Apr 2 2008 4:24 PM In reply to
     What is your Audio media type?
    I've seen this error in only a few instances and one time it was because MXF video files were being used with OMF audio files.
    Another thing I noted when I saw it was that the audio tracks were exactly 1 frame longer than the video for that master clip.
    Are you seeing that?
    **Also, it could just simply be some corrupt media**
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Apr 2 2008 4:31 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
    I think that erased some files directly of disk, those files was in the folder OMF files.
    What i can do?
  • Wed, Apr 2 2008 4:33 PM In reply to
    Jailer:
    What i can do?
    If you delete media files???
    Batch Capture or Batch Import
  • Wed, Apr 2 2008 4:41 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
     No, I want is clean disk from media tool, but projects don´t load completly.
  • Wed, Apr 2 2008 4:44 PM In reply to
     You can launch Media Tool from any project, even a new one.
    once open, select whatever projects and drive you want to purge media from and go to town.
  • Wed, Apr 2 2008 4:55 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
    When I load Media Tool, Xpress Show me the error: CM_NO_TRACKS_FOUND... and suposse that I have 25 projects and I select all projects, Media tool only show me 8 projects.
  • Wed, Apr 2 2008 5:00 PM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    What is your goal?  Are you trying to wipe the entire hard drive clean, or just delete some of the projects while leaving others?
    good luck,
    Carl
  • Wed, Apr 2 2008 5:08 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
     My goal is to erase media files that I don´t need, but in Media tool some stay hiden.
  • Wed, Apr 2 2008 5:09 PM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
      Moderator: Meridien
    Do you get the NO TRACKS FOUND error when you select any project?  Are there any projects you can select that do not have the error?
    good luck,
    Carl
  • Wed, Apr 2 2008 5:13 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    I'm having the same problem here whenever the Database loads. Can't, for the life of me, sleuth out the media file that is causing this.
  • Thu, Apr 3 2008 12:44 PM In reply to
    • Jailer
    • Posts 66
    • Points 830
    I get error when load all projects, and even I don't have detected which file is the problem.
