Latest post Wed, Apr 2 2008 2:34 AM by jwrl. 2 replies.
  • Tue, Apr 1 2008 11:46 PM
    • EliCross
    • Joined on Sat, May 27 2006
    • Posts 10
    • Points 150
    P2 was burned to dual layer DVD can't import into avid
     Hey Everyone
    Shot a spec spot with the panasonic hdx200. The camera's owner then burned the files onto 2 dual layer dvds for me. The first dvd has the contents file while the second has some random mxf files. Having a terrible time trying to import the footage into avid. I've tried coping the files into a another drive, that didn't work. Could import the footage of disc one but without the other files, it was full of errors "sys_error status 87, msg parameter is incorrect"
    Does anyone have a work flow for p2 footage that was burned to dvd
  • Wed, Apr 2 2008 12:05 AM In reply to
    • wsimonett
    • Madison, MS
    • Posts 60
    • Points 630
    Re: P2 was burned to dual layer DVD can't import into avid
     Sorry, Don't.  I know there is an issue with P2 on Macs. Have you copied to your hard drive?
    That should work.
    Check here and see if anyone knows anything
    http://www.dvxuser.com
    Dual 2 GHZ MAC.6 gig ram,3 gig hard drives, Avid w/ MOJO, FCP, Motion MBP Intel core 2 Duo,2.6 GHZ 4 gig ram, 17 inch Matte screen, Avid w/Mojo, &... [view my complete system specs]
  • Wed, Apr 2 2008 2:34 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 3,491
    • Points 40,375
    EliCross:
    It should be exactly the same as from any other media.  If you can't even copy the data fully it sounds like there might have been some corruption during the copy process.
