Latest post Tue, May 13 2008 5:33 PM by TCurren. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Mon, Mar 31 2008 9:19 PM
    • TrevorA
    • Posts 48
    • Points 580
    Idiot question: Resize an animatte
    V3 - animatte cut out of person
    V2 - empty track
    V1 - background image
    How do I resize the fill and cutout on V3 without affecting V1?
    Resize, 3D Warp, PIP all resize the composite of V3 over V1.
    Submastering makes no difference. Trying to mixdown resulted in some error message (as well as not really being what I wanted to do).
    Ended up outputting to tape and re-ingesting - not an elegant solution.
  • Mon, Mar 31 2008 9:34 PM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Idiot question: Resize an animatte
    Do you have BCC on the system?  I use the BCC Make Alpha when I want to move the cutout, because it's got geometric controls built in, and they only affect the cutout layer.
    If not, I'd try putting the Resize/3D Warp on V3 first, do the resize, and then nest that inside an Animatte to cut out around the subject on V3 (I'm not certain that'd work, but it's what I'd try first).
    good luck,
    Carl
  • Mon, Mar 31 2008 10:10 PM In reply to
    • TrevorA
    • Posts 48
    • Points 580
    I'll try the BCC plug in, thanks
    As for resizing then animatting - I need to have a dynamic resize, so I'd have to track my resize..
  • Mon, Mar 31 2008 10:11 PM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
      Moderator: Meridien
    TrevorA:
    Yeah, it would suck, but that's the only way I can think to do it.
    adios,
    Carl
  • Mon, Mar 31 2008 11:25 PM In reply to
    • TrevorA
    • Posts 48
    • Points 580
    Well if I hadn't got error messages I would have mixed down the fill and key of the cutouts then create a matte key with them that I could then have resized. As it is I used tape as my mixdowns. Glad I wasn't in a tapeless environment today.
    I'm just amazed that a finishing tool can't seemingly manipulate a cutout (like, say an ADO could ;-( ... but hopefully I'm wrong and someone will point out the error of my ways.
  • Wed, Apr 2 2008 10:36 PM In reply to
    • dan2008
    • Joined on Tue, Jan 29 2008
    • Posts 9
    • Points 135
    I think if you render the animate & then whilst in effect editor mode you can export a matte. Then reimport & use as a matte & fill, or apply the cut out to black & white titles & mix down to produce a clean matte & use the matte key to produce a dynamice resize.
  • Wed, Apr 2 2008 10:45 PM In reply to
    • TrevorA
    • Posts 48
    • Points 580
    Hmmm... a nice and simple solution ;-)
    I've said goodbye to this project but would guess that exporting a matte may have resulted in the same error messages as the video mixdown, as well as being a single frame rather than an animating matte.
    But I've been wrong before...
    Thanks for your input
  • Thu, Apr 3 2008 5:47 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 342
    • Points 4,095
    camoscato:
    good luck,
    Carl
    Carl,
    What's your workflow/settings for using BCC Make Alpha.  I can't seen to get it to affect just the AniMatte.
    Cheers in advance!
    HP 8600 Symphony Nitris DX v3 Sapphire v2.07 Boris Continuum Complete v5.8 AvidFX (Boris Red) Heroglyth v2.6 Vitascene v1 Adrenaline (XP 8400)... [view my complete system specs]
    Ra-ey Q: "How many Editors does it take to change a lightbulb?" A: "Why do you want to change it?"
  • Thu, Apr 3 2008 8:54 AM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
      Moderator: Meridien
    Ra-ey Saleh:
    You don't use it with the AniMatte, you use it instead of the AniMatte.  It does the same thing as AniMatte: you drop it on a clip, set the shape to custom, and draw the cut out shape.  After you've got the shape the way you want it, you have other parameters you can use to blur the edges or add a shadow or do DVE moves or whatever.
    good luck,
    Carl
  • Fri, Apr 4 2008 1:45 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 342
    • Points 4,095
    Thanks Carl, I misunderstood your previous reply.
    Now I have another problem.  When I make the Custom Shape I can't seem to 'close' it.  It just keeps on making more points.  I've searched the User Guide and can't seem to find the answer.
    What am I missing?
  • Fri, Apr 4 2008 6:53 AM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
      Moderator: Meridien
    If I remember right, you close the shape by clicking on the first point again.  I'm not in front of a machine to check, but I'm pretty sure that's all it is.
    good luck,
    Carl
  • Fri, Apr 4 2008 10:08 AM In reply to
    • Ra-ey Saleh
    • Sydney, Australia
    • Posts 342
    • Points 4,095
    Not on my machine, but it could be a quirk on my system.
    Oh well.
  • Fri, Apr 11 2008 9:55 AM In reply to
    • rogershuff
    • Hertford UK
    • Posts 112
    • Points 1,260
    Coming in late on this but you could temporarily remove the clip on V1 (or replace it with a slug of black), then render/mixdown and then use the matte key effect on the mixdown?.
    Mac: 2.33Ghz Macbook Pro, OS 10.5.3, 3GB RAM, analogue Mojo 120GB internal HD, Sony DSR-45P deck, etc etc [view my complete system specs]
    Roger Shufflebottom Bottom Line TV +44 7973 543660
  • Fri, Apr 18 2008 11:28 PM In reply to
    • TrevorA
    • Posts 48
    • Points 580
    Hi Roger
    This was a few weeks ago now - and I was having error codes coming up when I did the mixdowns - so I output to tape / altered what I was doing to make it easier.
    If I'd had AfterFX on the system I would have used that, because the whole mixdown of key and fill, drop back in timeline, apply matt key and then resize is a major PITA anyway.
    Trevor
  • Sat, Apr 19 2008 1:14 AM In reply to
    • EyeBee
    • Joined on Tue, Jul 24 2007
    • Posts 6
    • Points 95
    Hi Trevor / Roger,
    If it's of any consolation to  you - it just can't be done by using any of the Avid effects tools. This kind of effect, much loved by anyone used to performing the 'soft hand drawn matte / resize /move' type of thing - quick compositing for title sequences and graphics backgrounds, etc - just doesn't happen, because of the fundamental inability to promote the animatte effect to 3D. I'd love to hear of a realistic solution to this problem without the use of mixdowns, export/imports, etc. The export matte function only exports a still frame of the matte shape. This feature is a glaring omission in the tool set (especially in Symphony) particularly when competing systems (Smoke, etc, even as far back as EditBox) do it in a second.
    Regards, Ian.
    BTW, it is almost as big as an omission as being unable to colour correct a foreground layer in Spectramatte without affecting the keying ...DOH!
