Latest post Thu, Sep 25 2008 10:48 AM by Dimch. 11 replies.
Page 1 of 1 (12 items)
  • Mon, Mar 31 2008 11:03 AM
    • Dimch
    • Joined on Thu, May 17 2007
    • Kiev, Ukraine
    • Posts 32
    • Points 350
    Play Frame Error - in Assist application
    Hi all! Have these problem with my Interplay Assist: when try to view a video clip, in the video frame window we have "Play Frame Error" message. I don't know what to do, becouse simply restart of PC where Assist installed does not make y life better. With my Interplay system everything is OK: editors can work, Ingest still work, Access also work. What you would like to recommend for me?
    Unity 4.2.3, Interplay 1.2.4, NewsCutter 6.7, iNews 2.6 [view my complete system specs]
  • Mon, Mar 31 2008 11:49 AM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,625
    • Points 78,505
    Re: Play Frame Error - in Assist application
    Play frame error could be that you are trying to display a resolution not allowed by the application...
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Mon, Mar 31 2008 12:12 PM In reply to
    • LJBakker
    • Joined on Fri, Mar 2 2007
    • Amsterdam
    • Posts 15
    • Points 205
     Do you have an ISIS system?
    If so did you edit the lmhosts file in the appropriate way for the sysdir?
    ISIS 1.4 -- Interplay 1.2.3 -- Newscutter 6.8.3 -- Media Composer 2.8.3 [view my complete system specs]
  • Mon, Mar 31 2008 12:41 PM In reply to
    • Dimch
    • Kiev, Ukraine
    • Posts 32
    • Points 350
    Problem was fixed 5 minutes ago: it was just a bug of Portserver Pro system. I restart a PSP computer and problem is solved now. Thanks for all :)
  • Mon, Mar 31 2008 1:26 PM In reply to
    LJBakker:
    You need to log in to ISIS to allow the Assist to play video
    Felipe Gonzalez
    ACSR ISIS
    ACSR Interplay
    Avid Latin America
    La mente es como un paracaídas, trabaja mejor cuando se abre / Mind is like a parachute, it works better when it is open
  • Mon, Mar 31 2008 1:37 PM In reply to
    • Baklap
    • Posts 6,625
    • Points 78,505
    lol you are so right!!! Happend to many i know Smile
    felipousis:
    Menno
    Dutch AV forum
  • Mon, Mar 31 2008 1:39 PM In reply to
    • Dimch
    • Kiev, Ukraine
    • Posts 32
    • Points 350
    Well, I have to say: we using Unity 4.2.3 It's looks little different from ISIS system
  • Sat, Aug 30 2008 4:41 AM In reply to
     Hi every body
    This problem of Play Frame Error is very frequent in interplay 1.2.3 and what ever you do the troubles commes.  The file lmhost is at c:\windows\system32\drivers\etc.
    have you any idea ??
    I have got the same problem with differents models of PC: xw4300, xw4400
    System Administrator France24
  • Tue, Sep 2 2008 3:37 PM In reply to
    • Dimch
    • Kiev, Ukraine
    • Posts 32
    • Points 350
    What I find: this error message will bring up if you have problems with network speed and/or your grafics card have lower performance than needed.
  • Wed, Sep 3 2008 11:42 AM In reply to
    • Baklap
    • Posts 6,625
    • Points 78,505
    Also make sure you are able to play the resolution provided to the Assist station. Viewing high res media when the station is only allowed to view low res will also result in the play frame error.
    [edit] oops just noticed i already stated that before Smile sorry..[/edit]
    Menno
    Dutch AV forum
  • Fri, Sep 5 2008 10:53 PM In reply to
    Last sunday I have been detetected and fixed several problems with the network card configuration. We don't have problems any more but I will wait during two weeks at least before the toast :)
    many thanks
    I will back in two weeks for more details about the solution
    many thanks
  • Thu, Sep 25 2008 10:48 AM In reply to
    • Dimch
    • Kiev, Ukraine
    • Posts 32
    • Points 350
    This problem comes back again. Only one machine - and there are no differences from others. Couple of reloads of Assist does not change the situation.
    I have Interplay 1.2.4 with Unity MediaNet 4.2.3.
