Play frame error could be that you are trying to display a resolution not allowed by the application...
Menno
Dutch AV forumFCP2Avid I hear and I forget. I see and I remember. I do and I understand. - Confucius
Do you have an ISIS system?
If so did you edit the lmhosts file in the appropriate way for the sysdir?
LJBakker: Do you have an ISIS system? If so did you edit the lmhosts file in the appropriate way for the sysdir?
You need to log in to ISIS to allow the Assist to play video
Felipe Gonzalez
ACSR Interplay
Avid Latin America
El cerebro es como un paracaídas, trabaja mejor cuando se abre / Brain is like a parachute, it works better when it is open
lol you are so right!!! Happend to many i know
felipousis:You need to log in to ISIS to allow the Assist to play video
Hi every body
This problem of Play Frame Error is very frequent in interplay 1.2.3 and what ever you do the troubles commes. The file lmhost is at c:\windows\system32\drivers\etc.
have you any idea ??
I have got the same problem with differents models of PC: xw4300, xw4400
Jorge G Rodriguez Cruz System Administrator France24
What I find: this error message will bring up if you have problems with network speed and/or your grafics card have lower performance than needed.
Also make sure you are able to play the resolution provided to the Assist station. Viewing high res media when the station is only allowed to view low res will also result in the play frame error.
[edit] oops just noticed i already stated that before sorry..[/edit]
