Latest post Sat, Mar 29 2008 5:57 PM by jamdivo. 8 replies.
Page 1 of 1 (9 items)
  • Sat, Mar 29 2008 6:20 AM
    • jamdivo
    • Posts 8
    • Points 80
    HDV Playback issues
    Hello everyone: I have done some research about this problem but I haven´t found any reference to it in the forums. I am running MC on a laptop for quite a while, for the first time I am working on a HDV project. I had some problems with deck control while capturing the media but playback was fine. As I kept having more material digitized, playback problems arouse, first skipping audio and video while playing and some crashing. This seemed memory a problem so I began freeing memory space: stoped some processes, halted startup programs, computer performace maintenance... The persisting problem which I haven´t been able to solve is that video seems to be stable during playback but audio is delayed and echoed. I am using an HP ZD8000 Laptop 2 gb ram 2.8 P4 external HD 7.200 rpm Every help is must welcome :) Cheers! Jorge Divo
  • Sat, Mar 29 2008 9:49 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,232
    • Points 13,760
    Re: HDV Playback issues
    Try moving some media to your internal drive to test out wether your external HD is fast enough for HDV...
    MC 3.0 QTime 7.4.5 win xp pro service pak 3 Core 2 Duo Quad core 2.4 4 gig ram 667mhz pci x nvidia 512mb geforce 7600 162.50 driver 1 x 7200rpm... [view my complete system specs]
  • Sat, Mar 29 2008 10:17 AM In reply to
    • camoscato
    • Posts 4,685
    • Points 55,835
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Hi Jorge,
    What kind of audio & video cards do you have on the system?
    good luck,
    Carl
  • Sat, Mar 29 2008 2:41 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello, thanks for answering. Actually, I had all the media in the internal drive and moved ir to the external because of the playback issue. I agian did what you sugested, moved some clips to the internal drive and disconected the external, but still it does the same. I believe that ther should be some setting in the laptop that onflurnces this. Still am on the same spot, Thanks
  • Sat, Mar 29 2008 2:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    Could you do us a favor and list the system specs for that laptop, Including the Audio and Video cards please?
  • Sat, Mar 29 2008 3:09 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello, The audio card is altec lansing, I hag got no furhter specs. The vido card is ATI Mobility Radeon X600, 128 mb. I am still trying to workout what is going on for, as I sayd in the first post, at the beguining playback had no problems. Thanx
  • Sat, Mar 29 2008 3:37 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Ok, here is the update. I just switched the playback to half resolution and it is playing properly. This gives me some tranquility but leads me to believe that it is a memory issue. The media is still in the external drive. Any sugestions? Thanks
  • Sat, Mar 29 2008 5:49 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Hello Blkdog, the system specs: Brand: HP Product Line: Pavilion Notebook Operating System Compatibility: PC Operating System: Windows XP Home Processor Manufacturer: Intel Processor Type: Pentium 4 Processor Speed: 2.8 GHz Bus Speed: 800 MHz Level 2 Cache: 1 MB Hard Drive Capacity: 80 GB Installed Memory: 2 GB Maximum Supported RAM: 2048 MB Video Card Type: ATI Mobility Radeon X600 Video Card Memory: 128 MB Sound Card Type: Altec Lansing As I refered in my last post, I believe it is a memory issue because I can playback with no problem in low res. Though I will not need high res for editing, I will surely need it for D-Cut. Thank you for your help. Jorge
  • Sat, Mar 29 2008 5:57 PM In reply to
    • jamdivo
    • Posts 8
    • Points 80
    Re: HDV Playback issues - Last Update
    After dealing with several processes, cleanups and system performance routines, I have managed to playback in all availabel resolutions with no visible problems. I will keep testing to hopefully have steady stable performance. Please, If you have more suggestions I will suerely appreciate them. I will post further results. Thank you all, Jorge
