Latest post Mon, Apr 7 2008 10:04 PM by Luiselx. 2 replies.
  • Fri, Mar 28 2008 12:50 PM
    • Luiselx
    • Joined on Fri, Mar 28 2008
    • Posts 6
    • Points 70
    Problems with shared user settings file
    Hi
    I have a very often warning window when I start Avid appears:
        Unable to read shared user settings file. Make sure directory exists and is accesible.
    I'm using Avid Xpress Pro and Newscutter connected to Avid Lanshare with Avid Unity.
    Somebody can help me?
    Luis
    Filed under: , ,
  • Sat, Mar 29 2008 1:04 AM In reply to
    • lawsonr
    • Joined on Thu, Jun 8 2006
    • CBS News
    • Posts 160
    • Points 1,945
    Re: Problems with shared user settings file
    Have you exported your user profile to an external location? If so, did you choose "Personal" or "Group" in the export dialog box?
    You edit system is trying to sync your *local* user profile with the external copy, but can't find it. This may be because the file path has changed (for example, because you've mounted workspaces in a different order) or because the file path is gone (for example, because you exported your user profile to a USB key, which is in your pocket now).
    In the future, use Group as your export setting, and the edit system won't try to resync automatically.
    Avid NewsCutter Adrenaline 6.8.3, ISIS 1.4, Interplay 1.2.3. [view my complete system specs]
    Filed under: , ,
  • Mon, Apr 7 2008 10:04 PM In reply to
    • Luiselx
    • Posts 6
    • Points 70
     Thank you
    I created news user and delete the old because i formated the computer and i copied it at the users folder. Now no appears the warning window.
    Good job
