Latest post Thu, Mar 27 2008 12:03 PM by motoriley. 3 replies.
  • Thu, Mar 27 2008 10:57 AM
    • eddiefrost
    • Joined on Thu, Mar 27 2008
    • Posts 1
    • Points 25
    Merging fields
    Hi All, Does anyone know how I merge video fields when exporting a tiff screen grab on Avid? Want to export the best possible image. Thanks in advance. Eddie
  • Thu, Mar 27 2008 11:51 AM In reply to
    • motoriley
    • Joined on Thu, Sep 27 2007
    • Montreal
    • Posts 11
    • Points 130
    Re: Merging fields
    Use the de-interlace filter in photoshop.
    5.7 Xpress Pro HD Studio HP XW-80000 2 gig, NVidia 128 meg Also have a couple of Dell M60 laptops, Pentium M 1.7, 1 gig, Nvidia 128 [view my complete system specs]
    Riley Montreal
    • bsuttie
    • Edinburgh, Scotland
    • Posts 596
    • Points 7,555
    Re: Merging fields
     If you want the best possible image then you don't want to merge the fields.  Export a still with both fields.  If there is any movement between the two fields then selectively remove the movement in e.g. photoshop
    regards
    Brian
    Symphony, Adrenaline, Xpress Pro [view my complete system specs]
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Thu, Mar 27 2008 12:03 PM In reply to
    • motoriley
    • Montreal
    • Posts 11
    • Points 130
    Re: Merging fields
    bsuttie is correct.  If there is little or no movement in the frame don't de-interlace.  Try all the options using the de-interlace filter and go with what looks best which may very well be nothing.  The other thing to consider is that if you send out a 720x480 image it will have to be resized to correct the aspect ratio if it's being used for non-video purposes.  You can make it 640x480 or stetch it to 720x540 in photoshop.
    Riley Montreal
