Latest post Thu, May 8 2008 11:43 AM by tkgun. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Mar 27 2008 2:40 AM
    • tkgun
    • Joined on Wed, Mar 26 2008
    • Posts 6
    • Points 90
    problem with registering as Avid Interplay asset by TransferManager
     I have two avid workgroup and four TransferManager servers(hereafter TM) per workgroup.
    Avid's reseller told me TM can perform for registering asset as Avid's one.
    I tried to transfer OP1a clips in 3'rd storage to ISIS by TM.
    The clips can be transfered to ISIS as OPAtom successfully, but I can't find this clips in Avid Interplay by Avid Interplay Access.
    After exexuting  'Resync..' function in Avid Interplay Access, I can find that clips in 'Catalog/Resync/anyworkspace' folder.
    What is the problem? How can I solve this problem?
    Filed under: ,
  • Thu, Mar 27 2008 12:12 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,093
    • Points 23,040
    Re: problem with registering as Avid Interplay asset by TransferManager
    are you able to post a screenshot of your TM config window?  That would be very helpful for this.
    Best guess is your workgroup configuration in the settings, or the TM itself are not correct.
    JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Thu, Mar 27 2008 12:45 PM In reply to
    • tkgun
    • Posts 6
    • Points 90
    Attached file is capture image of TM config.
    Thank you for kindness.
  • Mon, Apr 7 2008 2:53 PM In reply to
    Do you have the TransferManager account with password avid created in the Interplay?
    Felipe Gonzalez Avid Latin America
  • Tue, Apr 8 2008 4:05 AM In reply to
    • tkgun
    • Posts 6
    • Points 90
     I have valid TransferManager account in the Interplay.
    I still can't solve this problem. Anyone who can solve this gives me help.
  • Tue, Apr 8 2008 12:41 PM In reply to
    Can you put a screenshot of the TrasnferManager Interplay account?, which settings this user have over the database?
    Regards
  • Wed, Apr 9 2008 11:06 PM In reply to
    • hdalton
    • NYC
    • Posts 4
    • Points 60
    Make sure to select the box "accept incoming workgroup transfers without Interplay login" on the Interplay engine Transfer Config window.
    Also make sure the following Admin account exists in Interplay and ISIS or Unity
    Acct:TransferManager
    Pwd: avid
  • Thu, Apr 10 2008 7:30 AM In reply to
    • tkgun
    • Posts 6
    • Points 90
    I already satisfy those settings as you commented.
    But I still can't check in at Avid Interplay via TransferManager.
  • Thu, Apr 10 2008 9:47 PM In reply to
    Does the TransferManager client Read/Write/Delete permissions over the entire data base?
  • Tue, May 6 2008 10:12 PM In reply to
    • jweis
    • Joined on Thu, Aug 17 2006
    • Posts 6
    • Points 40
    Having Access installed on the Transfer Engine is a requirement for the checkin to work.
    Also, the Interplay account being used can be specified in the TMConfig utility. It is not limited to Transfermanager/avid for this case.
    The Tm log file and the workgroup.log should shed more light on why this is not working
  • Thu, May 8 2008 9:10 AM In reply to
    • steve cho
    • Joined on Thu, May 8 2008
    • Seoul
    • Posts 1
    • Points 15
    For TM transferring asset check-in to interplay,
    The user account must Higher than READ/WRITE privilege in terplay administration tools.
    In Interplay Access,
    Login to interplay access (use administrator account)
    - Interplay DB > catalogs select
    - Mouse right click and interplay Security setting select.
    In Security Dialogbox
    - Folder option
    -- Allow Creation of sub folders option must checked
    -- Allow adding and removing of item .... option must checked
    - Roles option
    -- Full-down Menu > Transfer Manager User select
    -- higher than Read/Write privilege select
    Geeked
    Steve cho
    Windows 400 / MCA / Unity MN / Unity ISIS / Interplay ACSR
  • Thu, May 8 2008 11:43 AM In reply to
    • tkgun
    • Posts 6
    • Points 90
     Thanks you.
    I solved my problem by your comments.
