I've got my little G5 Dual 2Ghz machine here, with a couple external 250gig G-Drives, and a couple other firewire drives when needed. I've got my main system drive (with Leopard), and a 2nd 500 gig drive that's been split up and has Tiger on it so I can use my MC 2.8. I tried using my Leopard partition over a month ago, but Avid wouldn't work so I installed Tiger (I'm sure by scouring the forum I'll figure out how to make Leopard work), because I was doing back to back jobs at home and needed a working system.
Well, since you can only stick 2 drives in the old G5s, I just picked up a Sonnet G5 Jive, and their Tempo Sata card, so I could put a few more drives in (I've got my old 250gig drive that used to be in the spot where the new 500 gig Tiger drive is). I also just got my Mojo in today, mostly so I can finally have my client monitor running.
So the question is about should I Raid or not? I've never set up any of my computers to do it. Never really thought about using it as backup for media, because if stuff get's lost I'll just batch the tapes back in. Will I notice any real performance difference if I Raid a couple drives together? And which configuration to choose? All the info out there just confuses me. I'm good at following directions, but it doesn't neccessarily mean I understand how something works.
I rarely do "for pay" jobs from my home system, it's mostly personal stuff. But I do like to have my machines running as smooth as they can within reasonable costs (no point in spending over a 1000 on the machine, since I'll probably upgrade to an Intel Mac by the end of the year). And who knows when I'll actually get to play with my home Avid since I'll be starting my next editing gig in two weeks.
I've also got FCP on the system, so I'm not sure if that's something to consider. Generally I'd like to keep the media from both programs on separate drives.
Is there a "Raid for Dummies" thread somewhere on the board? Avid updated the look of the forums, but they should have overhauled the Search feature.
Any pointers will be appreciated.
Thanks,Erik
You'll want to make sure you have equal-size drives or equal-size partitions.
Setting up a software RAID is quite simple in Tiger or Leopard - use the Disk Utility under Applications > Utilities to stripe together drives. Disk Utility Help is actually quite good about this.
You will notice an overall increase in speed from a two-disk RAID0 array but it won't be incredibly different. I would download a disk speed test and try it with your specific set-up and see if it makes enough difference to warrant the possibility of losing 2x the amount of data if only 1 drive fails.
AJA has a decent speed test for Mac, and will give you some idea of the throughput possibilities of your storage(s): AJA KONA System Test Version 2
As for a 'Raid for Dummies' - Wikipedia is a good place to start.
HTH.
I guess the other question would be, does it make sense to have some media on raided drives and others not on raided drives? As I mentioned, I've got several firewire drives with media, and my pre-existing externals have media as well.
Hi there,
I think what I'm hoping to do is set up a RAID array, and do my editing on those drives... then when a project is finished, I'll copy it, and the associated media, and maybe some of the raw media, onto one of the (many, well, six) fw drives I've been using for the last few years.
So RAIDed drives for projects underway, and then 'archive' to fw drive.
sound good?
Malcolm
That's what I do mhcbc... I have 13 1TB and 2TB FW drives stacked up on shelf with all my old projects, media, graphic files, etc on them
Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
