Latest post Thu, Mar 27 2008 10:14 AM by breakaleg. 13 replies.
Page 1 of 1 (14 items)
  • Wed, Mar 26 2008 2:12 PM
    • breakaleg
    • Joined on Thu, Feb 8 2007
    • Posts 43
    • Points 530
    PROJECTS CAN'T OPEN
    hi every one,
    i recently updated from mc 2.7 to mc 2.8. everything went fine until i realized i had an avid media files/mxf folder on my computer instead of being on ext drive where i keep all my media. how it happened i don't know but i must've done something wrong (i keep an old omfi media file taht was for little projects i can schlep around without carrying the ext drive).  i transfered the mxf media (and the old omfi file too) in my ext drive, it's media, right? once copied in the ext drive, i trashed them, without empying the trash can. my avid projects bin is still in the same place.(documents/media composer/avid projects).
    now when i launch MC, i select a project and sometimes i get this message :" "news" not a valid project name. cannot use characters:/:*?<> OR leading spaces, trailing spaces, trailing period OR leading _". others open just fine.
    what's going on?
    thanks in advance
  • Wed, Mar 26 2008 2:34 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    Re: PROJECTS CAN'T OPEN
    Is there any chance that there is a space in front of that project's name?
  • Wed, Mar 26 2008 2:49 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    hi,
    No, i just checked. i don't get it, it was working fine before i moved the media files folders to the ext drive. what could've happened?
    thx
  • Wed, Mar 26 2008 2:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    That's the puzzler.
    Let me ask you this...If you take all of your drives offline. Does the error still come up with no media for the system to see?
  • Wed, Mar 26 2008 3:06 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    yes, the error still comes up.
  • Wed, Mar 26 2008 3:16 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    So we can forget about the media being the problem (Assuming you don't have any media on your internal)
    When you checked the project name, were you careful to check the .avp file itself or did you just check the folder?
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
  • Wed, Mar 26 2008 3:47 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    i don't have media on my internal anymore.
    my avid projects have always been in documents / avid projects folder/ projects name folders.
    i can see  an .avp file in each. when should i check the.avp files? i don't understand. thx for your patience.
  • Wed, Mar 26 2008 3:52 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    in the select project window / folder/ my project folder/ can't check the .avp file .
  • Wed, Mar 26 2008 4:12 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    ok,
    in finder /documents/ media composer folder/ avid projects folder/ one of my projects (that gets me the error message in "project window") folder/ click on the .avp file ...and it opens!
    beats me up!
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    That .avp file is the one you want to check for spaces or any errant characters. The Avid doesn't care about the folders.
  • Wed, Mar 26 2008 4:38 PM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    checked for spaces and errant characters. still get the same window error.
    i've getting this lately too ,  ever since i updated to 2,8:, when i close a project:
    " the project folder's name has been changed outside the editor! attic entries will put the demo et mickey folder instead of the demoetmickey folder. you should probably correct this by restoring the project folders name"
    what that means and is this related to the other problem?
  • Thu, Mar 27 2008 1:00 AM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Posts 95
    • Points 1,085
    I'd create a new project (news2 or similar) then in the finder copy and paste the bins/folders into it.
    2x MC 2.6.6 with Mojo on HP xw8400 MC Adrenaline 2.6.6 on HP xw8400 MC 2.8 on MacPro dual 2.66 Editshare 4.1 [view my complete system specs]
  • Thu, Mar 27 2008 10:14 AM In reply to
    • breakaleg
    • Posts 43
    • Points 530
    working! thanks man. still i'd like to understand what happened.
    and i still get that annoying message:
    "changed outside the editor"? editor being MC, right? i changed project names to get rid of spaces and in that case it make sense i get this message. but i never changed any project names prior to that.
    once again i started to get this message when i updated to 2,8.
    thanks guys.
