Latest post Tue, Mar 25 2008 11:36 PM by rebusfilm. 5 replies.
Page 1 of 1 (6 items)
  • Tue, Mar 25 2008 1:38 PM
    Need a "Red Carpet Photo Flash Effect"
     Greetings all,
    We're Green Screening two subjects in a frame that resembles the Red Carpet at the Oscars.  I'm wondering if anyone has an idea for an effect that makes it look like these folks are being photographed by lots of photographers w/flash bulbs?
    Thanks for considering!
    Tim Scarpino
    Avid MCA v2.6.4 on HP xw8200 Windows XP SP2 4 gig RAM QT v7.2 [view my complete system specs]
  • Tue, Mar 25 2008 1:49 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,837
    • Points 175,450
    Re: Need a "Red Carpet Photo Flash Effect"
    Any type of glow that cuts in and dissolves out in 4-6 frames will do it. NI has an optical glow that is particularly useful.
    You can also fake this using the RGB keyer on a an upper layer, key it white, cut it in and disolve it out quickly.
  • Tue, Mar 25 2008 3:52 PM In reply to
    • editzz01
    • Joined on Wed, Nov 23 2005
    • Montreal
    • Posts 734
    • Points 8,755
     You can cut in a lens flare (I believe it is the 50mm that is all white)....cut it in for around 2 frames for each flash.....you can also animate the size of the lens flare by using the instensity...I use either BCC lens or Saphire for this.
    Dual 3.2 Xeon 2.0MB L2 Cache Tyan Thunder i7525 800 FSB 2 gig DDR II PNY QUADROFX 3450 74 gig, 10 000 SATA WD Raptor OS Drive 4 x 300 gig SATA Seagate... [view my complete system specs]
  • Tue, Mar 25 2008 4:06 PM In reply to
    • rebusfilm
    • Malmo, Sweden
    • Posts 171
    • Points 2,235
    Are the photographers in frame or just the subjects?
    iMac 24" 2.4 GHz Core 2 Duo| 3 GB RAM OSX 10.5.4 Avid Media Composer Software 3.0 Sony DSR-1500P JVC DTV1710 [view my complete system specs]
    Jorgen Persson
  • Tue, Mar 25 2008 6:36 PM In reply to
    No photographers...Just the subjects.
    Similar to this only a bit more intense...
    http://www.youtube.com/watch?v=xQYeL7RInsg
    Tim Scarpino
  • Tue, Mar 25 2008 11:36 PM In reply to
    • rebusfilm
    • Malmo, Sweden
    • Posts 171
    • Points 2,235
    I would roto them out on a single frame with animatte and color correct it brighter.
    Or export single frames to Photoshop and use the Dodge tool.
    Jorgen Persson
