Latest post Mon, Jul 28 2008 1:16 PM by jeabby. 56 replies.
Page 4 of 4 (57 items) < Previous 1 2 3 4
  • Mon, Jun 30 2008 11:40 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 228
    • Points 3,090
    Re: P2 Workflow
    Let me ask this.
    Will exporting with RGB levels not stretch my levels from 16-235 space into 0-255.  Therefor, if I color correct using a 0-255 scale, will exporting RGB not stretch out those values crushing the blacks further, and pushing the whites up higher?
    But, on the other hand, if I exported 601 (even though its not meant for broadcast) it would leave my levels exactly as they were in the Avid timeline?
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Tue, Jul 1 2008 12:07 AM In reply to
    • tobyjt
    • Joined on Sun, Sep 2 2007
    • England
    • Posts 156
    • Points 1,865
    Re: P2 Workflow
    no Stick out tongue
    if you export at 601, in an RGB world (like the internet / PC screens), the black will be at 16 and look milky and the white at 235, which will look dull. If you export RGB you will export the entire range 0-255. So I would suggest ccing in 0-255 and exporting RGB.
    I think....give it a go on a clip, I think this is the way to go.
    Toby
    HP Dual Xeon XP Pro Workstation 'turnkey' Nitris Symphony / DS workstation / MacBook Pro Media Composer 2.8 OS X Tiger 4GB RAM/ Unity Lanshare... [view my complete system specs]
  • Sun, Jul 6 2008 4:56 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 202
    • Points 2,665
    Re: P2 Workflow
    Tobyjt;
    Take a look at this document: <http://www.24p.com/HVX200_1.htm>
    The Avid can mix any supported coded with any frame size (1080, 720, SD) as long as they have "like frame rates."
    Where this gets confusing are the names Panasonic uses. For example, 720p/24 isn't a 24p frame rate, its a 720p/59.94 clip with frame segmentation added to give the clip a 24p look. This will not play in a 24p project type. That document lists all the names Panasonic uses with the Avid project they will natively work in.
    No render means an Avid can't render to the AVC-I codec like it can render to the DVCPro HD, DNxHD codec. The AVC-I clips can be imported like any other P2 card and edited with right away adding real-time effects.
    -- Bob Russo Applications Editor at Avid Technology
  • Sun, Jul 6 2008 6:17 PM In reply to
    • tobyjt
    • England
    • Posts 156
    • Points 1,865
    Re: P2 Workflow
    OK.....where'd that come from!? Smile
    Some people on the forum here are having trouble using AVC-Intra100 and rendering (even after setting render to a DNxHD codec).
    I know about the resolution independancy of Media Composer, so where'd that come from? Stick out tongue
    Toby
  • Sun, Jul 6 2008 6:22 PM In reply to
    • tobyjt
    • England
    • Posts 156
    • Points 1,865
    Re: P2 Workflow
    And what about the Panasonic AJ-HPX3000 1080p AVC-Intra100 camera, that does 'proper' 24p doesn't it ?
  • Sun, Jul 6 2008 6:28 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 202
    • Points 2,665
    Re: P2 Workflow
    There is a bug with 3.0 and rendering clips that are AVC-I to a different codec. This should be fixed in the next patch release.
    I was replying to this post:
    tobyjt:
    "Panasonic DVCPRO HD
    • DVCPRO HD - 100 Mb/s
    • AVC-I (no render)
    • Native project formats: 1080i/59.94, 1080i/50, 720p/60, 720p/25, 720p/23.976
    Can someone confirm if it is by purpose or misstake there is no statement about 720p/50?"
    what does (no render) mean ?
    ...Does the new MC3 support 24p 1080, AVC-Intra 100 off of P2 (from a Panasonic AJ-HPX3000)..if so, are there any issues/transcoding I need to be aware of?
    thanks
  • Sun, Jul 6 2008 7:04 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 202
    • Points 2,665
    Re: P2 Workflow
    As far as I can tell, the HPX3000 can record AVC-I 100 @ 1080p 23.976. But this is called 24pN - N for native. 24p is not the same thing.
    Bob
  • Sun, Jul 6 2008 7:42 PM In reply to
    • tobyjt
    • England
    • Posts 156
    • Points 1,865
    Re: P2 Workflow
    Does anyone know a good place (web/documents) to start researching for a 23.976 to film out (24p) workflow (incl. audio).?
  • Sun, Jul 27 2008 9:41 AM In reply to
    • jeabby
    • Posts 24
    • Points 325
    Re: P2 Workflow
  • Sun, Jul 27 2008 9:45 AM In reply to
    • jeabby
    • Posts 24
    • Points 325
    Re: P2 Workflow
    Let's me ask this. I import EDL from FCP to continue editing in AVid MC 2.8.3
    by imported P2 media to media drive and import by clip to bin.
    After that i cant relink EDL to MEdia.
    What should i do?
    Thank you
    Jeabby
  • Sun, Jul 27 2008 1:00 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 202
    • Points 2,665
    Re: P2 Workflow
    The Media Composer doesn't read the timecode on a QuickTime File. Import the QuickTime files into MetaCheater and save an ALE file. Import that ALE file into a bin and Batch Import the QuickTime files, they will now have the metadata. http://www.staticpictures.com/
  • Mon, Jul 28 2008 1:16 PM In reply to
    • jeabby
    • Posts 24
    • Points 325
    Re: P2 Workflow
    Hi Bob,
    Actually, If you modified reel number for quicktime file so avid can read it.
    cheers,
    Jeabby
