Latest post Wed, Oct 8 2008 7:14 PM by Dwaltjj. 59 replies.
Page 3 of 4 (60 items) < Previous 1 2 3 4 Next >
  • Fri, Jun 6 2008 6:58 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    No Bill. I just heard from Bob. He's on the road promoting the new gear so getting back to the forums is tough for him.
    I'll give him another tap on the shoulder tomorrow.
  • Mon, Jun 9 2008 9:27 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
     Well, I didn't see this as an issue on the lengthy list on the v3.0 readme.  But still, I don't want to upgrade my copy of xpress pro to media composer until I hear something about this... mainly cuzz im sitting on the fence on software at the moment.
    I feel like Media Composer is gearing itself towards broadcast use, and since i have a good amount of work that stays digital and/or web delivery, Avid may not be the right tool for those jobs.
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Mon, Jun 16 2008 7:01 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    Still hoping/waiting for word on this.
  • Tue, Jun 17 2008 3:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    Ok, I talked with Bob at Avid and, so far, they are not seeing this problem there.
    Did you guys check your general settings to see if the "NTSC has Setup" button is checked? If so, did toggling it do anything (It's been so long I don't remember f we tried that yet)?
  • Tue, Jun 17 2008 5:22 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    The only thing I can see changing when I toggle the "ntsc has setup" button is that in the YC Waveform monitor, the IRE side of the graph changes so that my black level is either 0 or 7.5 (the voltage stays the same).
    Let me ask this.  If I shoot a black card with an ntsc HD camera, and while shooting adjust the iris so that the black level recording is IRE = 0, I then capture that media into Avid... should the RGB level be 0 or 16?  Also, should the IRE level be 0 or 7.5?  I assume this last question is dependant on the camera settings.
    As it is now, the RGB value is coming out to be 16 on my tests... but I don't know if this is correct.
    By the same notion, if I import a complete black Tiff file with RGB levels 0,0,0... what should the black levels be on import to Avid?  0 or 16?
  • Tue, Jun 17 2008 5:42 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    If you are looking at a digital scope, the black should rest on 0. Analog scopes would be 7.5.
  • Tue, Jun 17 2008 5:48 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    How about the RGB level?
  • Wed, Jun 18 2008 4:07 PM In reply to
    • tobyjt
    • Joined on Sun, Sep 2 2007
    • England
    • Posts 158
    • Points 1,915
    Re: P2 Workflow
    "Panasonic DVCPRO HD
    • DVCPRO HD - 100 Mb/s
    • AVC-I (no render)
    • Native project formats: 1080i/59.94, 1080i/50, 720p/60, 720p/25, 720p/23.976
    Can someone confirm if it is by purpose or misstake there is no statement about 720p/50?"
    what does (no render) mean ?
    ...Does the new MC3 support 24p 1080, AVC-Intra 100 off of P2 (from a Panasonic AJ-HPX3000)..if so, are there any issues/transcoding I need to be aware of?
    thanks
    HP Dual Xeon XP Pro Workstation 'turnkey' Nitris Symphony / DS workstation / MacBook Pro Media Composer 2.8 OS X Tiger 4GB RAM/ Unity Lanshare... [view my complete system specs]
  • Wed, Jun 18 2008 4:45 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    Here are the supported formats and their appropriate project types:
    DVCPro HD     1080/59.94i - work in 1080i/59.94 project
    DVCPro HD     1080/29.97p  (over 59.94i) work in 1080i/59.94 project
    DVCPro HD     1080/23.98p  (over 59.94i) work in 1080i/59.94 project
    DVCPro HD     1080/23.98pA (over 59.94i) work in 1080i/59.94 project
    AVC-Intra 100 1080/29.97p (native) work in 1080p/29.97 project
    AVC-Intra 100 1080/23.98p (native) work in 1080p/23.976 project. This has just been rounded up for the menu in the camera.
    Projects support AVC-I and DVCPRO as appropriate.
  • Wed, Jun 18 2008 5:06 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Re: P2 Workflow
    now that's a useful format matrix, don't suppose you have one for 720 and it's many flavours....incl HDV etc.? ....these things seem to be spilt up over many Avid format whitepapers...i.e. he one for HDV, the one for p2, the one for HD RGB etc....it would be nice to have one giant matrix with everything on it.
    thanks alot BLKDG
    Toby
  • Wed, Jun 18 2008 5:10 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    Avid is working on publishing just such a matrix
  • Wed, Jun 18 2008 6:57 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Re: P2 Workflow
    I'm not sure if that's good news or bad news...whenever Avid are 'working' on something, it means it'll take minimum 6 months. Wink
  • Wed, Jun 18 2008 9:25 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Re: P2 Workflow
    hmm....I can't seem to edit my above post.
    anyway....back to my original question...what does 'no render' mean ?
    thanks
  • Wed, Jun 25 2008 9:09 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    Hi all,
     So I have been in this limbo of color, levels, IRE, blah blah.  I think I'm actually wrapping my head around it and, thankfully, am starting to understand where I have gone wrong.
      Without getting into it, let me ask this a question, but first positing a couple statements:
    1) Avid works in YUV space.
    2) on the Avid scopes, 16 RGB is as black as I want to get.
    3) If i export a quicktime with the above black level, and I select RGB-levels on export, it will pull those down to 0,0,0.
    So, I am working with p2 footage that is going directly to quicktimes on the web.  Should I be balancing all my black levels at 16 (and 235 for white) and exporting a quicktime with the RGB option selected on output?
  • Mon, Jun 30 2008 11:31 PM In reply to
    • tobyjt
    • England
    • Posts 158
    • Points 1,915
    Re: P2 Workflow
    If it's solely for internet use and not broadcast, I would grade in 0-255 (turning the limiter off) and possibly grade on a (decent/calibrated) PC monitor, since this is the end market....not TV. I would then export RGB.
