Latest post Wed, Oct 8 2008 7:14 PM by Dwaltjj. 59 replies.
Page 1 of 4 (60 items) 1 2 3 4 Next >
  • Thu, Mar 20 2008 4:12 PM
    P2 Workflow
    Locked Reply Contact
    Hey guys... there's a new P2 tutorial here for you.
    http://www.avid.com/p2/
    Also, check out this pdf.
    http://www.avid.com/p2/p2guide.asp
    MC 3.0.5, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Thu, Mar 20 2008 4:58 PM In reply to
    • MrBill
    • Jackson, MS
    • Posts 16
    • Points 190
    Re: P2 Workflow
    Cool -thanks!
    Dual Core G5 Avid Media Composor/ With Mojo P2 HD Camera [view my complete system specs]
    MrBill Loft54.com
  • Thu, Mar 20 2008 9:25 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 455
    • Points 5,320
    Re: P2 Workflow
    This is great stuff.  I'm thinking Avid might be waking up from the 'tutorial-as-a-profit-center' approach.  Hopefully we P2 users will actually be able to do what the tutorial describes very shortly...
    MC v3.0.5 thru SDI Mojo, OS 10.5.5, QT 7.5.5, on G-5 Octo 2.8 w/10 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display, NVIDEA... [view my complete system specs]
  • Sat, Apr 26 2008 7:53 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 455
    • Points 5,320
    Re: P2 Workflow
    ...and I hope I don't have to pony up $$ for 3.0 so that I can once again perform what I was able to do in 2.6 or 7, namely have the app see the volumes from the actual P2 device and use them in a timeline.
  • Wed, May 14 2008 7:54 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    Speaking of p2 content, I brought this up in the forums some time ago, but I have never been able to figure it out.
    The color levels of p2 media are very different when i load a clip into Avid versus when I load the same clip into either Final Cut, Premiere or After Effects.
    Does anyone know about this??
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Fri, May 16 2008 8:08 PM In reply to
    • cls105
    • Los Angeles, CA
    • Posts 128
    • Points 1,830
    Re: P2 Workflow
    and whats the latest on sony ex1 and its cards/importing.  I dont see anything about it on the latest media composer mac 2.8.3 readme.  thanks a lot.
  • Fri, May 16 2008 8:22 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    As kind of a side note to that post, yesterday I just doanloaded an update for Premiere Pro to edit xdcamEX natively...
    just sayin...
  • Fri, May 16 2008 8:31 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    x.8.3 will import and edit the 35MBS file type from the EX1. You convert it with Sony's clip browser and off  you go.
  • Fri, May 16 2008 10:46 PM In reply to
    • cls105
    • Los Angeles, CA
    • Posts 128
    • Points 1,830
    Re: P2 Workflow
    great.  thanks blkdog (i was hoping you would be the one to answer my question).
  • Sun, May 18 2008 12:53 AM In reply to
    • Bill Nelson
    • West Coast
    • Posts 455
    • Points 5,320
    Re: P2 Workflow
    P2 EX what?!   JK...  that color difference was not apparent to me when I did that yesterday.  Perhaps how you're calling out your timeline prefs in FCP?
  • Thu, May 22 2008 4:12 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    I'm mean p2 in Avid.  I think Avid adds Setup to the clips on import.  My black levels are always higher in Avid than compared to when I import the same MXF file into After Effects
  • Thu, May 22 2008 4:19 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    Are you coming  in 601 or RGB? Is "NTSC has setup" checked in your General settings (If you are working in NTSC that is)?
  • Thu, May 22 2008 4:25 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    I have tried all sorts of combinations over the past several days to try to figure this out.  I spoke with the DP yesterday and he said he definately had the camera set to 0 (HPX500 shooting to p2 cards)
    And as per the 601 versus RGB question, there is no way to change that option when importing p2 media, correct?  It is always the same, and I don't know how its doing it.  If there is a way to change the setting, please let me know ;)
    Also, at this very moment I am looking at p2 material that was imported with both "ntsc has setup" checked and unchecked, and the content is identical.
  • Thu, May 22 2008 4:29 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,267
    • Points 168,385
      Moderator: MCA Mac
    Re: P2 Workflow
    Ok. I wasn't sure if you were actually importing the media or re-wrapping.
    If you look on a scope, where do the blacks fall?
  • Thu, May 22 2008 4:45 PM In reply to
    • lmerino
    • Chicago
    • Posts 241
    • Points 3,235
    Re: P2 Workflow
    I have attached an image of the Avid scopes and reference frame.  The DP assures me the black behind the woman was at 0 when they shot it.
