Latest post Tue, Mar 18 2008 7:29 PM by stokesmm. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Mar 18 2008 6:53 PM
    • stokesmm
    • Posts 21
    • Points 320
    Problem re-linking PSD files to timeline
    we can re-link the new PSD files to the old ones, but it is only letting us do it ONE LAYER at a TIME. (which blows!) we have about 25 files, w/ about 6 layers each.
    anyone suggest a way that will re-connect all the layers at the same time, per psd file?
    when we try to do this it says "Error, cannot read Mac0S Files" - or something to that effect.
    thanks!
    Filed under: , , ,
  • Tue, Mar 18 2008 6:56 PM In reply to
    Re: Problem re-linking PSD files to timeline
    stokesmm:
    Are you using a pre-5.8 version of XpressPro?
    Also, I would suggest using png files as opposed to psd's, you won't have to deal with the layers
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Tue, Mar 18 2008 7:01 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,278
    • Points 180,890
    Using Photoshop docs is a great way to import only one file with a bunch of different layers and edit them all in at once. We use this often for Price and item stuff.
    Relinking is very simple if you brought them in as a "Sequence of Layers" in the import process....did you?
  • Tue, Mar 18 2008 7:04 PM In reply to
    • stokesmm
    • Posts 21
    • Points 320
    the reason they need to br brought in as different layers is because they need to come in and fade in and out at different times. like different points of a speech being made. make sense?
    • stokesmm
    • Posts 21
    • Points 320
    sequence of layers. can you explain?
  • Tue, Mar 18 2008 7:07 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,278
    • Points 180,890
    When you import your .psd file, you are asked if you want to import as a sequence of layers or as individual files. If you import as a sequence, you can then batch capture any of the individual layers simply by pointing the batch dialog box to the original .psd.
  • Tue, Mar 18 2008 7:20 PM In reply to
    • stokesmm
    • Posts 21
    • Points 320
    Yeah, we imported them as a sequence of layers. Our old "sequence of layers" is currently in our timeline. All where they need to be. we had to re-color the psd files, so, we did that, and now we have new psd files, as a sequence of layers, that we need to replace w/ the older ones.  The problem we are having is that Avid let's us do this, but only per layer. Not per the entire psd file (which are made up of layers).
    If we have to re-import every single layer by themselves, than fine, but that is going to take up a ridiculous amount of time. there has got to be another way.
  • Tue, Mar 18 2008 7:25 PM In reply to
     So, which version of XpressPro are you on?
    There was a bug in pre-2.8 MC that exhibited the exact same behavior your describing "Mac OS error", I would venture to guess that it's present in pre-5.8 XpressPro as well.
  • Tue, Mar 18 2008 7:26 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,278
    • Points 180,890
    If you are on the current version, you should be able to select all of the individual clips that make up that sequence, select batch capture and point them all to the one .psd file. Avid should sort out the layers for you.
  • Tue, Mar 18 2008 7:29 PM In reply to
    • stokesmm
    • Posts 21
    • Points 320
    Thanks so much for your explination. You are correct, we are at ExpressPro 5.7
    crap- :)
    well, you think after we upgrade we should be good to go?
