Latest post Mon, Jun 16 2008 6:25 AM by Randall L Rike. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Mar 17 2008 12:54 AM
    Displaying Timecode over Video within Sequence
    Take advantage of the timecode plugin available in the Illusion FX category of Avid Effects. If you would like to have timecode of the sequence displayed on the playback, create a new video track, and apply the effect to it. Avid Xpress systems will require the user to add an edit to the track in order to apply the effect to the filler track. This will display the sequence timecode over the video. If you would like the timecode to display for each individual clip in the sequence, the effect must be applied to each clip separately. Note: The timecode plugin is a Non-Real-Time effect and will need to be rendered in order to play back.
  • Wed, Mar 19 2008 11:31 PM In reply to
    • ela-luca
    • Joined on Sat, Jun 9 2007
    • Posts 2
    • Points 20
    Re: Displaying Timecode over Video within Sequence
    Is there any possibility to reverse the timecode (in AVID Xpress Pro HD 5.2.1.), counting down to zero?
    Thanks a lot!
    Ela-Luca
  • Thu, Mar 20 2008 12:17 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 13,244
    • Points 168,010
      Moderator: MCA Mac
    Not with the current Plug-in.
  • Thu, Mar 20 2008 3:59 PM In reply to
    You could create a green background, super the BITC, mixdown, reverse, chromakey.
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Thu, Mar 20 2008 4:00 PM In reply to
    • camoscato
    • Posts 4,499
    • Points 53,770
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    In addition to Job's excellent suggestion, you could also lay in the timecode effect, mixdown, reverse and PiP.  Smile
    good luck,
    Carl
  • Thu, Mar 20 2008 4:54 PM In reply to
    Agreed, Carl, but that is assuming a TC window with a solid background, rather than just the counter. Although you could luma key that in combination with the PIP.
  • Mon, Jun 16 2008 6:04 AM In reply to
    • hartfilms
    • Joined on Wed, Nov 16 2005
    • Los Angeles
    • Posts 55
    • Points 625
     Is it possible to make the window and font bigger than what is available in the FX Parameter drop down menu? I am working with DNxHD 145 media (including FX media creation) and after rendering the window is so small it is unreadable. I just updated my profile--am now using MC 2.8.1 and have added 2 raid-striped internal drives to my system.
    Jayasri
    Media Composer 2.8.1 w/ Mojo SD, Win XP Pro w/ SP2 System built and upgraded by Avid reseller: ASUS P5W DH Deluxe Motherboard; Intel Core 2 Duo Processor... [view my complete system specs]
  • Mon, Jun 16 2008 6:21 AM In reply to
    I believe the RT TC effect included in v3.0 allows you to change font style and size.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 3x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Mon, Jun 16 2008 6:25 AM In reply to
    That is correct.  It has effects controls similar to Title Tool
