Boris Continuum Complete AVX 4.2’s Match Grain filter takes a snapshot of film-to-video (“telecined”) media and generates a grain signature which is than applied to a destination clip that has very little or no grain. A common application of this filter is adding grain to computer-generated imagery to lend to a more realistic composite. Match Grain can also be used to grain footage shot on video so it edits more seamlessly into a sequence with telecined media.
To demonstrate how BCC Match Grain’s automatic grain sampling is used, I will borrow grain from a clip of a surfboard surfacing from the ocean depths. Then, I will apply that grain to a computer-generated sphere I composited onto the tip of the surfboard.
Click here to view the ungrained video (Please allow a moment for the movie to load)
* Don’t be alarmed by the appearance of the sphere at this point. The grain hasn’t been applied yet.
To capture the most convincing grain match that will “sell your shot”, finesse the ‘Sample Controls’ explained below:
Generally, the larger the sample region = better results.
Once the Sample Layer is assigned, BCC AVX Match Grain conveniently copies the grain pattern from that clip, creates a grain signature and automatically applies it to your ungrained image. To show you the power and accuracy of the match grain algorithm, I’ve provided screen shots of the grain when viewed through each color channel.
The Red and Green Channels contain fine grain that is not so obvious. Notice how the grain on the sphere matches the background grain pretty well.
Even the very grainy Blue Channel is accurately mirrored on the sphere.
CCDs used in scanners are famous for being noisier in the blue channel when scanning color negative film. This is because the transmittance through the film is lowest in that channel. For an explanation see: http://www.aim-dtp.net/aim/technology/sensitometry/
Just say you have a whole edit sequence that needed this fabulous grain you just sampled. You can save your generated grain as a preset that can be loaded and used on your other clips.
Since our Artbeats media was shot in 16mm, we couldn’t take advantage of the many 35mm motion picture stock presets that come standard with the BCC AVX Match Grain filter. Each preset was designed to emulate the grain found in processed 35 mm color negative film.
Click here to view the rendered composite with the grain applied. (Please allow a moment for the movie to load)
John Lafauce is a visual effects artist and lead compositor who has worked on over thirty feature films in Hollywood for such companies as Sony Pictures Imageworks, Rhythm & Hues and Pacific Title. He currently works in software quality assurance for Boris FX in Massachusetts. Away from work, John writes about digital effects and compositing for various online communities, and spends time with his wife, twin sons and parrot, Layla.
