Latest post Fri, Mar 21 2008 4:42 AM by JVR. 14 replies.
Page 1 of 1 (15 items)
  • Fri, Mar 14 2008 9:04 PM
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    firestore and HD
    hey guys
    ok been running 8 firestore fs4proHD for the last year....   no problems.
    but we been running in DV mode only.  with sony PDs and Z1s and DSR450s
    and ive had the firestores set to Avid OMF.
    what a timesaver on big multicam shoots....
    well anyways...  now my client has moved to HD.  true Sony HDcam, 1080/50i   Not HDV.
    so now we have our next big series coming up.   and from what i can see, my Firestores are useless now.  If we were using HDV cams we would have been fine, but not with true HD.
    my question.  i have to find a replacement to the firestores.   and it needs to be DTE technology.
    Is there anything out there for HD, and it needs to intergrate with avid, like DNxHD, or something that we can just drag and drop.   Anything that needs to long import, i dont want, coz then i may as well shoot on tape and capture.
    our shows need to turn around FAST.    Record on Saturdays and Tx on sunday.   so no time to digitize for a day....   (unless i was running like 5 composers :(    )
    if there is no DTE technology available for HD,  what other formats might you recommend to do similar job like XDcam????   thats a simple drag and drop hey?  (never worked with it)
    have many avids all different, so cant post all specs... will rather say as required [view my complete system specs]
  • Fri, Mar 14 2008 9:10 PM In reply to
    Re: firestore and HD
    Have you ever looked into the Ikegami stuff?
    Ikegami DNxHD field recorder HDE-X11
    http://editcam.ikegami.com/index.php/products_recorders/dne_31/
    http://www.avid.com/thirdparty/guide/guide-item.asp?productid=135
    I've never used it, but it sounds like something you could use. The field recored looks like it will accept HD-SDI and record it to hard drives as DNxHD.
    MC 2.5.1 with Analog Mojo. HP xw8000, dual 3.0 Xeon, 3 Gig Ram, nVidia FX1100, ADS Pyro Firewire Card. [view my complete system specs]
  • Fri, Mar 14 2008 9:20 PM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,198
    • Points 13,320
    The FS-100 firestore DTE I just purchased it. It records in MXF and other various formats I use it with my HVX202EN and record DVC PRO HD/100.
    Check out the specs pretty sure it would do the job...
    http://www.focusinfo.com/solutions/catalog.asp?id=150
    MC 3.0 AXP 5.8.3 QTime 7.3 win xp pro service pak 2 Core 2 Duo Quad core 2.4 clocked to 3.1 4 gig ram 667mhz pci x nvidia 512mb geforce 8600 162... [view my complete system specs]
  • Fri, Mar 14 2008 9:35 PM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    oh man wow, that jvc looks awesome
    but at what price :(
  • Fri, Mar 14 2008 9:41 PM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    cant use the fs100, coz we shooting Sony HDcam.
  • Sun, Mar 16 2008 9:55 AM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    surely we can invent a solution here :)
    here in africa a firestore costst the same as a decent laptop.
    if i was on fcp i could use an aja solution  (HD SDi to laptop and capture)
    but so far the only DNxHD solution seems to be the Ikegami....  but man that is expensive.
    is there some other HD format i can capture that i wont have to "import" into avid?
    i vaguely remember trying a demo of some software .....   it gave you realtime scopes etc on a laptop, i think adobe bought that product....  but DNxHD wasnt an option
  • Sun, Mar 16 2008 12:02 PM In reply to
    • Tugger
    • Champaign Illinois USA
    • Posts 381
    • Points 4,740
    You're thinking of "DVrackHD", that bacame Adobe "On Location". I run with that for longer form projects, it captures firewire fed HD as QTs (natively uses DVCproHD codec I think) so it requires importing (and not fast-almost twice real time) there is a selection for using "AVID codec" (DV100 I think) but that still equires the same lengthy imports. One thing to keep in mind: the file size of HD files are huge, I also use a Firestore FS-100 (100 gig size) and just moving the files from the firestore onto a storage drive takes almost real time (1 hour of footage-45 minute transfer) I've learned to figure the extra amount of time into the workflow.
    Not to be sacrsanct (sp?) as a loyal and long time AVID user, but in your situation "On Location" and FCP would be the most efficient. Capture to external drive then just point to the captured stuff as your "scratch folder" and start editing.
    good luck
    MediaComposer 3 on HP nw9440 (2.17ghz dual proc-nVidia 1500m-4gig RAM) / AXP 5.8 on HP zd8000 (3.2ghz P4 proc-ATI X600-2gig RAM) USB or eSATA external... [view my complete system specs]
  • Mon, Mar 17 2008 7:58 AM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    lol...  you can never make  me use fcp :)      (i own it but refuse to use it)
    fcp and long form multicam ...  hell no !
    im waiting on prices today from ikegami's DNxHD recorder. lets see
  • Tue, Mar 18 2008 8:18 AM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    oh well thats a disaster....  the ikegami solution is more expensive than an adrenaline.....  lol
  • Tue, Mar 18 2008 1:12 PM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    lol i seems to be talking to myself now....  but anyways
    how about one of those HD- SDI to firewire converters???
  • Thu, Mar 20 2008 11:33 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,198
    • Points 13,320
    Hey guys I didn't want to start a new thread so if you don't mind I'll ask my? Here re the FS-100.
    I'm just wondering seeing that the firestore records using the FAT 32 FILE SYSTEM and has the 2gig limitation in MXF what are you all doing with the material once ingested. For e.g. I just imported about 2 hrs of continual footage and have about 100 clips and just wondered how to join them into one seamless file instead of having this great mess.
    Am I missing something here is there a way import the media so you have one continual file?
  • Thu, Mar 20 2008 9:22 PM In reply to
    • monkeyberry
    • bushveld
    • Posts 363
    • Points 4,525
    they should just butt up against each other no problem on a timeline...  and run continuous into each other.
  • Thu, Mar 20 2008 11:16 PM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,198
    • Points 13,320
    Monkeyberry,
    They do but up nicely but I just wondered if there was a way to have a seamless clip (all one piece) not a bunch of clips in a sequence.
    Anyone?..................
    Bump
  • Fri, Mar 21 2008 12:50 AM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 615
    • Points 7,480
    No, not in a practical way...  I hate that problem too... everything nice and neat!
    So my new wife asks me about my "Avid Forever" tattoo... I told her she's an old girlfriend who was always coming up with new things for me to try...
  • Fri, Mar 21 2008 4:42 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,198
    • Points 13,320
    That's no good I wonder if other NLE's can import as a seamless file?
