Latest post Tue, Aug 11 2009 9:52 PM by Larry Rubin. 11 replies.
Page 1 of 1 (12 items)
  • Sat, Mar 1 2008 3:59 PM
    • vamvax
    • Greece - UK
    • Posts 60
    • Points 870
    Sequence not playing after Quarantine of corrupt files
    Hello, after moving my project from one avid to another and back I had some corrupt files which I succsefuly quarantined. But now when I try to play a couple of my sequences I get an error saying "offset exceeds length of stream". Does anyone know what I can do about that? Thanks!
    Ok I just spotted that the problem seems to be on specific effects. When I click on them I get the above error on the screen and then an error on the composer monitor saying "structure error".
    Yiannis
    Avid Xpress Pro HD 5.2.4 with Mojo [view my complete system specs]
  • Sat, Mar 1 2008 5:11 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,009
    • Points 107,230
      Moderator: Meridien
    Re: Sequence not playing after Quarantine of corrupt files
    It sounds like you may have some effects files that are corrupted as well. Try this. Save the suspect effects templates to a bin, then remove them from the clips. Re-apply the effects templates and re-render, then see if the problem persists. Also, since you've been moving the project around between platforms, you should delete and rebuild the Media Database files.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Mar 1 2008 6:27 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,580
    Larry Rubin:
    I'd suggest to begin with Larry's second recommendation !
    What's your opinion Larry ?
    Adrenaline MCA 2.8 XW8400 3Gb RAM DNxcel Board, 760 Gb striped SCSI media storage, 1.2 TB 4 X striped SAS 15 000rpm storage.----MC Soft 2.8 + Mojo HP XW8000... [view my complete system specs]
    sep
     Web site : www.audiacom.com
  • Sat, Mar 1 2008 7:57 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,009
    • Points 107,230
      Moderator: Meridien
    Yes, sep is correct. Start with the database rebuild. That alone might solve the problem.
  • Sun, Mar 2 2008 1:21 AM In reply to
    Also, check the files/folder count.  With MXF media, I'm still seeing bogus Quarantine attempts, due to file count ... with as few as 3,500 files.  My vote is still for 2,500 max.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sun, Mar 2 2008 1:44 AM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,580
    after the "early bird...."
    EXCELLENT, Randall !Big Smile
    sep
  • Sun, Mar 2 2008 6:10 PM In reply to
    • vamvax
    • Greece - UK
    • Posts 60
    • Points 870
    Thanks for the replies! I had already deleted and rebuilt the database files on all drives before posting but it didn't work. Many of my effects but also some video too where linked to corrupt files anyway. I think that the project itself is somehow corrupt.
    What worked for me is that I turned off the drive that I had used to move the project from one avid to another, I deleted all the database files on all drives, I opened a new project and opened the bins from the old one and all the previously corrupt files seemed to be ok. The only problem with that workaround is that I can't have access to the files from the turned off drive (obviously), because whenever I turn it on it all happens again. Maybe I have some douple media files on 2 different drives? I don't know. Any help welcome!
    Yiannis
  • Sun, Mar 2 2008 6:23 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,009
    • Points 107,230
      Moderator: Meridien
    Since you can open and use the suspect material in a new project, I would suspect that your "(Project name)settings.avs" file is corrupted in the original project. You could try deleting that as well.
    As to your other issue, it sounds like you have a bad drive. If you have duplicate media on different drives, you can change linkage of pointer/media files by using the unlink/relink function and when re-linking, target only the appropriate drive.  Then have your suspect drive checked out.
  • Sun, Mar 2 2008 6:29 PM In reply to
    • sep
    • France
    • Posts 5,593
    • Points 62,580
    Sometimes permissions issues can be the culprit, However you'll see the "access denied" message.
    sep
  • Mon, Mar 3 2008 11:57 PM In reply to
    • vamvax
    • Greece - UK
    • Posts 60
    • Points 870
    Thanks for all the replies and input. It seems to be working ok now that I have put aside the damaged drive and relinked to old duplicate media from other drives.
    Yiannis
  • Tue, Aug 11 2009 9:36 PM In reply to
    • Ace Editor
    • Joined on Fri, Jan 4 2008
    • Jupiter Productions
    • Posts 23
    • Points 240
    All my projects and media are playing fine BUT, I use Media Mover software for backup and it does not recognize my last 4 projects properly (2 it doesn't see) - instead it sees a huge unknown MXF project.  If I quarantine the corrupt files to do my Media Mover back up - can I then put them back in the media folder to continue the project editing?  Some files are 25 GB movs from Final Cut HD so they would take a long time to re-import.  I'm using MC Adrenaline V. 2.8.4.
    Nancy
    MacBook Pro, 2.33 Ghz, Core 2 Duo and G5, Power PC, 2.7 dual with AdrenalineHD both running Media Composer 2.7.2 [view my complete system specs]
  • Tue, Aug 11 2009 9:52 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,009
    • Points 107,230
      Moderator: Meridien
    Ace Editor:
    If I quarantine the corrupt files to do my Media Mover back up...
    What is it that makes you suspect you have corrupt files if, as you say:
    Ace Editor:
    All my projects and media are playing fine...
    Now:
    Ace Editor:
    This alone does not necessarily mean you have corruption issues. Where are you seeing this "unknown MXF project"? The select project window? Somewhere else? Posting a screen shot here would be helpful. If you're unfamiliar with how to do that, click on the "options" tab at the top of the reply field, then click on "add/update" to browse for the file, select it and then "save", then post.
