Latest post Fri, Apr 4 2008 4:30 PM by DMcL. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • Sat, Mar 22 2008 7:05 AM In reply to
    • bogie
    • Posts 198
    • Points 2,385
    Re: Dolby E on Sysmphony Nitris
    'There is no frame delay added as you aren't coding / decoding, just copying a data stream. '
    That is correct, however at the playback end there will be a DolbyE decoder that will require 1video frame equivalent time to restore the original discrete tracks and make them audible.
    Accordingly, a DolbyE encoded track must be 1 frame in advance on tape.
    And BTW, you could always do a simple sync check with the 2pop after you layback to tape.
    cheers,
    bogie
  • Mon, Mar 31 2008 11:28 PM In reply to
    • TrevorA
    • Posts 38
    • Points 460
    bogie:
    Not necessarily. Some stations require DolbyE track to by synchronous with video - and thus deal with the decoding delay themselves (by use of Video Frame Delay)
  • Tue, Apr 1 2008 12:04 AM In reply to
    • Blue Crow
    • Joined on Mon, Oct 23 2006
    • Posts 389
    • Points 4,775
    I've been capturing HDSDI from HDCAM SR stereo left and right A1/A2 with Dolby E on A3/A4 then laying back to tape without any sync issues. Terence said he'd done this for a while without any issues and I haven't had any either.
    xw8200 Avid Adrenaline version 2.7 , xw8000 Symphony 5.5.7 , Symphony Nitris dual boot DS versions 1.7.7 & 8.4 Lanshare Lp 4.2.3 , ISIS 1.4 [view my complete system specs]
    Any sufficiently advanced technology is indistinguishable from magic. Arthur C. Clarke
  • Tue, Apr 1 2008 7:53 PM In reply to
    • bogie
    • Posts 198
    • Points 2,385
    'Some stations require DolbyE track to by synchronous with video'
    could you provide such an example?
    thx,
    bogie
  • Tue, Apr 1 2008 9:25 PM In reply to
    • TrevorA
    • Posts 38
    • Points 460
    The Dolby E encoded signal should be in sync with the stereo signal ON
    TAPE.  This positioning allows further processing to be done to the final
    tape if required.  The DolbyE signal will be advanced by 1 frame in the
    play-out chain to compensate for the Dolby decoder delay
    from <http://www.bbc.co.uk/guidelines/dq/pdf/tv/hd_summary_delivery_formats_v1_7.pdf>
  • Wed, Apr 2 2008 1:21 PM In reply to
    • DMcL
    • Joined on Tue, Jan 3 2006
    • Posts 173
    • Points 2,240
    Re: Dolby E on Symphony Nitris
     Our deliverables are:  tapes we get are advanced a frame and then when we decode they are in sync in Avid.  Then we encode and dolby is delayed.  Our playback for air then ingests the show and adjusts the sync on their end.  Confusing?.......yes!
  • Wed, Apr 2 2008 10:48 PM In reply to
    • TrevorA
    • Posts 38
    • Points 460
    I'm interested, why do you need to decode? Are you editing 5.1 within SN? More than simple cuts/dissolves (i.e. layering audio)?
    If not then you *should* be able to just take the DolbyE in and out invisibly - it is just data and is only subject to delays on encode/decode cycles. Dolby make it 1 frame so it is easier to fix.
  • Thu, Apr 3 2008 8:38 AM In reply to
    • Blue Crow
    • Posts 389
    • Points 4,775
    Do you have a link to the BBC spec with the 5.1 Brian as I don't have it in mine.
  • Thu, Apr 3 2008 9:09 AM In reply to
    • bsuttie
    • Edinburgh, Scotland
    • Posts 585
    • Points 7,380
    Sure, here you go
    regards
    Brian
    Symphony, Adrenaline, Xpress Pro [view my complete system specs]
    "We'll fix it in post"
    "This is post"
    "aaaahh"
  • Thu, Apr 3 2008 12:52 PM In reply to
    • DMcL
    • Posts 173
    • Points 2,240
     Yes, usuallly lots of editing.
  • Thu, Apr 3 2008 4:49 PM In reply to
    • Blue Crow
    • Posts 389
    • Points 4,775
     Thanks Brian that's very useful indeed.
  • Thu, Apr 3 2008 4:50 PM In reply to
    • Blue Crow
    • Posts 389
    • Points 4,775
     Our of interest Brian what sort kit have you been using for the BBC edits ?
  • Thu, Apr 3 2008 7:36 PM In reply to
    • TrevorA
    • Posts 38
    • Points 460
    I am interested to know how you are making those edits in SN.
    Are you corralling the audio 6 mono tracks at a time?
    How are you dealing with surround panning? And upmixing from stereo and mono sources?
    Are you having to deliver mixed and m&e versions of the 5.1?
    I have to hope that Avid have a solution to all of this with containerised audio sometime soon (other than DS ;-)
  • Fri, Apr 4 2008 9:57 AM In reply to
    • bsuttie
    • Posts 585
    • Points 7,380
    We haven't delivered Dolby E to them yet, only HD deliveries so far have been Stereo on HDCam.
    Onlined on Symphony Nitris
    regards
    Brian
    "This is post"
    "aaaahh"
  • Fri, Apr 4 2008 4:30 PM In reply to
    • DMcL
    • Posts 173
    • Points 2,240
     Decoding the dolby (5.1+2 is what we get and make) brings in the the dolby mix on ch 1-6 and 7 and 8 are the stereo mix.  The M/E or MixMin is brought in the same way.  16 channels of audio in your sequence and then any audio you have to add.  In the edit room, we have 5 speakers set up to moniotr the dolby.
