BustedFlush
jes
Any update on this? I need to buy a Keyspan or viable alternative.
Jef
to jef; No reply from Keyspan but their product seems to work fine for most users, if installed correctly. I'm still stumped on my problem but I now use my analog/dv converter's(Datavideo DAC-15) Rs-422 port and it works but with problems outputting.
So I read this thread because I did a fresh install of Mac Leopard, Media Composer 3.5. i have a Sony PVW-2800 with zero control. i am up and running with this setup.
Download Driver from Keyspan
in my Deck Config. I set up a new channel with a DIRECT connect using my USA28x3d1p2.2 (plugged my serial into port 2).
I then connect it to my Sony deck. Hit apply and close.
I went to my "communication (serial) Ports" (a couple options above Deck Config. in the settings)
I chose keyserial1
I have deleted both my Serial network settings in system Prefs.
I then opened digital cut and check decks. it worked.
note: I did the communication (serial) port first, though I don't know if this makes a difference.
Make sure the COMMUNICATIONS PORT and CONTROLLER SETTINGS are both set to NONE. It might also be worth resetting your P-RAM and disk permissions.
I found that my Mac was sharing the port with Bluetooth. So when I turn Bluetooth off when starting up AVID and it no works fine...
