Latest post Fri, May 9 2008 8:45 PM by Kevin Klimek. 23 replies.
Page 2 of 2 (24 items) < Previous 1 2
  • Wed, Mar 26 2008 4:30 PM In reply to
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 238
    • Points 3,200
    Re: new 1.8 codecs in After Effects 16-bit
    I will install these and check them out now.
    Question, in the install directory there is the Assumptions document that states:
    "Avid Codecs LE is not currently installed"
    The best I can do is uninstall the codecs, right?  Also, when I do uninstall the codecs, I see that the Avid components still exist in "..quicktime/QTComponents"  I end up overwriting those with the new install.
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Wed, Mar 26 2008 4:39 PM In reply to
    • lmerino
    • Chicago
    • Posts 238
    • Points 3,200
    The 1.6 codecs do work fine.
    Also, I see that the 1.6 codec components are dated 9/10/2007
    I have been using other codec components that are dated 11/13/2007 and they have been working fine as well.
    Another thing I noticed.  When I uninstall the codecs via windows Uninstall, it does not remove the components from the quicktime directory.  I must manually remove the files before installing a new codec package if I am going down in version (such as 1.8 to 1.6)
    Lucas
  • Wed, Mar 26 2008 4:55 PM In reply to
    • Quilt
    • Tewksbury MA
    • Posts 452
    • Points 5,465
    • Avid Customer Service
      Avid Employee
    That is all great info. I recommend using the 1.6 DNxHD codecs for the time being. Unless you wanted to get real adventuresome and replace only the 1.8 AvidAVdnCodec.qtx with the 1.6 leaving the rest. That way you could use all the 1.8 codecs as ususal except for the DNxHD codec.
    The problems with the 1.8 DNxHD codecs and CS3 has been brought to the attention of engineering. I'll post here once I get more information.
  • Wed, Mar 26 2008 8:29 PM In reply to
    • Quilt
    • Tewksbury MA
    • Posts 452
    • Points 5,465
      Avid Employee
    If there is anyone else out there having this problem can you please:
    1.) Download the Avid16bitEnable.zip from the following link.
    Click Here
    2.) Unzip the Avid16bitEnable.zip and place the Avid16bitEnable.jsx file within:
    C:\Program Files\Adobe\After Effects\Scripts\Startup
    3.) Relaunch AE CS3 and try the 1.8 DNxHD codecs in 16bpc again.
  • Wed, Mar 26 2008 10:00 PM In reply to
    • lmerino
    • Chicago
    • Posts 238
    • Points 3,200
    Unfortunately this did not fix the issue on my machine.  It seems that AE reacts the same.
    Lucas
  • Thu, Mar 27 2008 8:47 AM In reply to
    • andro
    • Warsaw
    • Posts 69
    • Points 955
    Hello
    Don't  solve problem for me as well. Same behaviour in AE.
    Andrzej.
    Avid MC 3.0 Vista 64 Adrenaline HD HP xw8400, FX 1500, 8GB ram. 2* Avid MC 3.0 Vista 64 Mojo SDI HP xw8400, FX 1500, 8GB ram Avid MC 3.0 XP Mojo SDI... [view my complete system specs]
  • Thu, Mar 27 2008 9:24 AM In reply to
     I would still export to QT Animation if I were you. It always works perfectly.
  • Wed, Apr 30 2008 1:19 AM In reply to
    • lmerino
    • Chicago
    • Posts 238
    • Points 3,200
    Has there been any update to the issue of the 1.8 dnXhd codecs in 16-bit/32-bit mode for After Effects?
  • Fri, May 9 2008 8:45 PM In reply to
    The bug has been found and a fix is in the works.  It is in testing now and should be released along with MC 3.0 next month.
    MacPro Symphony Nitris DX (v3.0), MacPro MCA HD (v3.0), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
