Latest post Fri, May 9 2008 8:45 PM by Kevin Klimek. 23 replies.
Page 1 of 2 (24 items) 1 2 Next >
  • Sat, Feb 16 2008 2:45 AM
    • lmerino
    • Joined on Mon, Dec 19 2005
    • Chicago
    • Posts 249
    • Points 3,365
    new 1.8 codecs in After Effects 16-bit
    Running AE cs3 on WinXP.  I just installed the new 1.8 codecs and now I ma having serious crash problems working in 16-bit color space in After Effects.
    I have a dnxhd clip (specifically I am using 23.976fps, 720p, 90)
    If the AE settings are set to 8-bit I have no problems at all, as soon as I click that 16-bit button it crashes.  Also, the session can be in 16-bit as long as I'm not viewing a dnxhd clip.  As soon as my marker hits a dnxhd clip, it crashes.
     Anyone else?
    thanks
    Lucas
    Dell Precision M90 WinXP-SP2 4GB RAM MC 3.0 [view my complete system specs]
  • Tue, Feb 19 2008 3:08 AM In reply to
    Re: new 1.8 codecs in After Effects 16-bit
    I'm not an engineer, so I'll play dumb, but ARE the DNxHD codecs 16-bit?  I didn't think they were.
    Did this setup work with the older versions of the codecs?  Do other 16-bit codecs also cause AE to crash?  (AE CS3 is not known for stability yet.)
    MacPro Symphony Nitris DX (v3.0.5), MacPro MCA HD (v3.0.5), Mac Meridien (v12.1.2), Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Tue, Feb 19 2008 3:17 AM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    I don't believe the bit-depth of the codec has anything to do with the bit-depth of an AE project.  I can use any codec on my system in a 8, 16, or 32 bit AE project.
    I could not stop the crashes at all, and in the end I had to manually go into my quicktime directory:
    C:\Program Files\QuickTime\QTComponents
    and remove the Avid components manually.  Then I re-installed an older version of the codecs and everything is fine.  I do a lot of color correcting and budget "onlining" (as it were) in After Effects in either a 16-bit or 32-bit sessions.  So it's essential that I be able to bring the clips in.
    Thanks for replying, I thought my post would be lost into the abyss ;)
    Lucas
  • Tue, Feb 19 2008 3:26 AM In reply to
    If I get a chance myself, I try it this week.  If I also can get it to crash, I'll report it Engineering.
    I haven't used AE CS3 much myself, but I have heard it's buggy.  Do you hear anything about other codec issues in the AE forums at Adobe or Creative Cow?
  • Tue, Feb 19 2008 3:29 AM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    Nothing specific, but I'll keep a look out.
    I have been using cs3 since about when it came out, and I haven't had too many problems.  In any case, thanks for the help.
    Lucas
  • Fri, Feb 22 2008 3:26 AM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    Where you able to get the same results as I did?
  • Sat, Feb 23 2008 3:45 PM In reply to
    Sorry, haven't had a chance yet...I'm in the middle of a two-week edit.  That ends Monday, so I'll definelty get to it early this week.
  • Sat, Mar 22 2008 5:03 AM In reply to
    • sean90291
    • Joined on Fri, Oct 21 2005
    • Toronto, Canada
    • Posts 258
    • Points 3,605
    Yup, I'm getting 16 bit crashes in AE after installing new Avid codecs too.
    Red, shmed. This was shot with a cell phone: http://vimeo.com/1649221  Edited in Avid.
  • Sat, Mar 22 2008 1:41 PM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    Sean, thanks for confirming this.
    What do we do now??
    Anyone else?
  • Sat, Mar 22 2008 2:47 PM In reply to
    • sean90291
    • Toronto, Canada
    • Posts 258
    • Points 3,605
    I seem to be able to convert all non-Avid DNxHD files to 16 bit and 32 bit in After Effects CS3. But cannot convert the DNxHD files to 16 or 32 without getting a crash in After Effects. This problem seems to coincide with upgrading to the new Avid codecs.
    I reverted to After Effects 7.0, and the issue with the DNxHD/Avid QuickTimes went away.
  • Tue, Mar 25 2008 7:48 PM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    So there seems to be a conflict with the new DNxHD 1.8 codecs and After Effects CS3 that causes direct a direct crash.
  • Wed, Mar 26 2008 2:44 AM In reply to
    Sorry about the delay...I will forward this to Avid engineering ASAP.
  • Wed, Mar 26 2008 2:37 PM In reply to
    • Quilt
    • Tewksbury MA
    • Posts 458
    • Points 5,555
    • Avid Customer Service
      Avid Employee
    Some PC users have experienced problems not just with DNxHD codecs but all QT codecs crashing any app that accesses them. For these users a common fix is the following Answer on the KB.
    Click here
    Give that a shot and let us know if it fixed the problem.
  • Wed, Mar 26 2008 2:57 PM In reply to
    • lmerino
    • Chicago
    • Posts 249
    • Points 3,365
    I switched Quicktime into Safe Mode and, unfortunately, it did not fix it.  AE CS3 still crashes in 16 and 32-bit modes with the new DNxHD 1.8 codecs.
    Lucas
  • Wed, Mar 26 2008 4:17 PM In reply to
    • Quilt
    • Tewksbury MA
    • Posts 458
    • Points 5,555
      Avid Employee
    Do the DNxHD 1.6 LE codecs have the same problem? I noticed that the 1.6 codecs were not available so I created an answer and attached the 1.6 LE installers.
    Click Here
    Let us know if this fixed the issue.
