Latest post Mon, Jun 15 2009 4:46 PM by GusC. 4 replies.
  • Tue, Jan 29 2008 9:25 AM
    Going from DS Nitris to Avid Xpress
    Hi, I've a project shot in HD.
    I have to capture the HD tapes with DS Nitris, and need to take the media to an Avid Xpress to be edited.
    After editing I have to bring it back to Nitris to do the finishing.
    How can I capture DNxHD at, let's say 115mbts and then import the media created into an Avid Xpress??
    Does MXF media creating support timecode?? I need this because I have to take back the finished project to NItris to do the finishing and recapture without compression.
    I heard something about setting MXF directories in NItris to be able to create MXF in capture, otherwise Nitris creates .gen files, which Avid Xpres doesn't support.
    Is there anybody who has done this before???
    Thanks in advance.
  • Tue, Jan 29 2008 2:47 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: Going from DS Nitris to Avid Xpress
    Hello,
    Just so you understand clearly that DS is indeed an Avid product but it is different from the other products by its meta data structure.  You can capture your media and clips in DS but you can only export EDL files from the DS to import in Avid Xpress.  DS is not creating Projects and Sequences data that is compatible with other Avid products.
    DS can writes MXF or GEN media files.  You make this decision when you configure its storages and select either MXF or GEN.  Same for audio: you select either MXF or WAV.
    The majority of users will create the project and capture the media with Media Composer or a product capable of handling HD and DNxHD, then export the project as AFE.  Work rarely starts on a DS to migrate to an Avid.  DS has been designed as a high-end finishing solution.
    Avid DS import the AFE data and relinks to the MXF media.  If compressed, the media cna be used for verification and the same clips can be recaptured uncompressed for the finishing.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Fri, Feb 8 2008 9:44 PM In reply to
    • Patch
    • Joined on Thu, Aug 31 2006
    • Montreal
    • Posts 24
    • Points 270
    Hello!
    First, capture you're HD tape with DS Nitris and use MXF Files or GEN Files.  If you can, capture with the DNxHD 36 resolution.  Than download DS Assist trial version (45 days of trial).  I hope 45 days is enough for you.  Archive your project, copy your media (GUID) on your drives (could be Firewire drives) and restore your project and Edit with DS Assist... At the end, send it back to the DS Nitris.
    Why use AVID Xpress Pro???
    Check www3.softimage.com web site for Minimal requirements for a generic Avid DS Assist Station platform.  The graphic card is the most important...Not all graphic card give a real time playback in DS. Go with the FX 1500 if you can.
    http://www.avid.com/products/tryout.html
    Voilà!
    6 DS Equinox (Compaq EVO w8000) 2 DS Nitris (HP xw 8200) 4 MC Adrenaline HD (HP xw 8200) 1 MC Adrenaline (HP xw 8200) 1 MC Adrenaline (HP xw 8400 Dual... [view my complete system specs]
  • Mon, Jun 15 2009 3:51 PM In reply to
    • chuck67
    • Joined on Tue, May 5 2009
    • Posts 2
    • Points 30
    I am trying to take a DS edl and import it into Avid MC. How do you do this?
    I open edl manager and grab the edl from DS, no problem. When I try to save it as a sequence, it doesnt happen.
    thanks for any help
  • Mon, Jun 15 2009 4:46 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 362
    • Points 4,375
    • Moderator: Avid DS
    chuck67:
    thanks for any help
    Do you get any errors in the EDL Manager console?
    Are the framerates the same?
