Latest post Mon, Dec 29 2008 4:54 PM by Jeyrem. 35 replies.
Page 2 of 3 (36 items) < Previous 1 2 3 Next >
  • Fri, Mar 14 2008 3:20 AM In reply to
    Re: LOST CONNECTION TO SERVER ????? grrrhhhh
    bengo82:
    I have in the monitor tool, 22 drive error on the same drive. it may be due to this error but it started 2 days ago. I change this disk Monday.
    I don't understand, did you have 22 errors first and replaced that drive, or did you replace the drive on Monday and then it had 22 errors?
    bengo82:
    ...I have the intuition the message appears more often when the client is idling.
    What exactly is that message? Is that the "Lost connection to server" ?
    bengo82:
    ...I made a little search in internet and I found this link below : http://support.microsoft.com/kb/138365/FR/ Maybe it's a related to the idling situation explained above.... Thanks Andrei for your interest and patience (for my english ;-)))
    As my limited French tells me, this has to do with Ethernet, so it wouldn't be applicable.
    Give me more detail about the Nitris stations, please. Are they running on ATTO FC42ES or 41XS? Is the driver version 2.51? Is everything green in the Unity client profiler when ran on them?
  • Fri, Mar 14 2008 12:16 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,132
    • Points 23,540
    change the FR at the end of that link to EN, and you'll get the english version. JDS
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Mon, Mar 17 2008 4:41 PM In reply to
    • bengo82
    • Joined on Thu, Jan 17 2008
    • Posts 17
    • Points 235
    I have 22 errors first and replaced that drive this night.
    Yes, the message is the "Lost connection to server"
    My nitris run with Celerity 41XS, the driver is 2.51, flash version is 2.50, Device discovery : Port WWN, Connection mode : PTP Preferred. For me, all is configured right.
    I hope that all that comes from the hard drive.
  • Wed, Mar 19 2008 11:01 AM In reply to
    • bengo82
    • Posts 17
    • Points 235
    I changed the disk failed and there is always the same error :
    "LOST CONNECTION TO SERVER"
  • Wed, Mar 19 2008 2:14 PM In reply to
     At this point, trouble shooting this can be very tricky. You should consider hirering a specialist to look at this problem.
    Next in line is the FC switch. What model do you have, what firmare and configuration is running on it?
  • Wed, Sep 3 2008 10:50 AM In reply to
    • vince73
    • Joined on Wed, Sep 3 2008
    • Posts 1
    • Points 15
     Hi guys
    I got the same issue here
    Could you explain me what was your solution ?
    I followed your discussion and as well, everything has been investigated but without success....
    thanks a lot
  • Thu, Sep 4 2008 5:04 AM In reply to
    Hi all,
    Here in LA with 24 clients on a 5.01 MediaEngine. Get the same issue every now and again... I'll check back in to see if we have a solution!
    (1) MediaEngine File Manager v.5.0.1 (2) MEDIArray XT (1) ArchionHD 26TB Unity Media Composer Adrenaline 2.8.0, 2.8.3 G5 Duals and Quads, MacPros all... [view my complete system specs]
  • Thu, Sep 4 2008 8:15 AM In reply to
    • Jorgito
    • Joined on Thu, Apr 24 2008
    • Murcia
    • Posts 2
    • Points 20
    I had the same issue. I replaced the net card and it worked for me.
    Try other computer's card and if it works, just replace it.
    Avid Unity ISIS Avid iNews Avid Media Composer Avid NewsCutter Avid iNews Instinct Avid Nearchive [view my complete system specs]
  • Wed, Sep 24 2008 8:33 PM In reply to
    • digitalcore
    • San Francisco, Ca
    • Posts 48
    • Points 660
    getting the same errors now also...
    mixed, 10.5.4 and 10.4.11 environment.  Avid/FCP
    Nubus, ABVB, Meridian, DNX [view my complete system specs]
  • Mon, Oct 27 2008 10:44 PM In reply to
    I had a similar with incompatible mac OS version and Unity.
    Do all the clients disappear at the same time. If so, you can be sure that it is a Unity issue & it is best to reinstall the machine from scratch, making sure to correctly install the right ATTO drivers. If not, you must have machines that have systems that correspond to the right version. 10.4.10 & MC 2.77 are not right. Upgrade to 2.8.
    I have 14 macs 2.66ghz OS 10.4.11 on a Unity v5.1. All of my disconnection issues disappeared when I upgraded the system, have ing the right client steup and above all with ATTO cards on both the PC & the Macs that were setup properly. If the issue continues, you should have an avid support policy. I suggest you use it. You may have a defective system.
  • Tue, Oct 28 2008 9:40 AM In reply to
    • bengo82
    • Posts 17
    • Points 235
    Thanks a lot for your response.
    An avid expert analysed and said  : all of my configuration is good, for unity, switch, and mac, etc...
    but there is this bug.
    my configuration is :
    19 adrenaline 2.8.4 ; mac os 10.4.11 ; 2,66 Ghz ; 4go RAM ; Unity 5.1 ; 40To
    to be continued.....
  • Tue, Oct 28 2008 11:30 AM In reply to
    Does it happen on all of the machines at the same time? If so, it is a server issue and often an ATTO card issue or the switch. Make sure that the ATTO cards of the clients and the unity are configured the same way, preferaby in Piont to Point
  • Tue, Oct 28 2008 12:55 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 14,278
    • Points 180,880
    Bengo, have you been able to give Avid Customer Suport a call about this problem?
  • Tue, Oct 28 2008 1:09 PM In reply to
    • bengo82
    • Posts 17
    • Points 235
    one machine at the same time and random.
    have you got my snapshot of my config in a file attachment ?
    thanks for your interest with my problem
  • Wed, Oct 29 2008 8:43 AM In reply to
    • bengo82
    • Posts 17
    • Points 235
    At this point,
    there is a team of Avid which appraises our problem.
    For the moment, there is no response. For them, our installation is conform.
    I would like just to compare with another user my configuration.
