Latest post Sun, Apr 27 2008 7:13 PM by Willstruthers. 3 replies.
  • Wed, Jan 23 2008 12:47 AM
    • pa90125
    • Joined on Wed, Jan 23 2008
    • Posts 2
    • Points 50
    Troubles to read real time video with nvidia GeForce 8400M GS
    I've just installed avid free dv 1.6 on my laptop (HP 6500 dv - 2x2ghz - 2g ram - windows vista premium-  nvidia geforce 8400M GS - realtek soundcard).
    I had no install problem, apart from the "switch to xp pro to run this program" compatibility procedure, but everythig is ok, shooting dv rushes as well under vista.
    The problem appears when I want to "play" the video, either in the composer or on the timeline : the image freezes, the sound is ok but the image is freezed, although I can edit it.
    I can only see it by moving the timeline freehandly, "play" just freezes the video.
    I reinstalled my graphic card but the result is the same and it seems to me the problem comes from the card not well configured to follow avid.
    Does anyone have an idea about what to do (apart from removing vista or my graphic card from the computer) ?
  • Wed, Jan 23 2008 2:06 AM In reply to
    Re: Troubles to read real time video with nvidia GeForce 8400M GS
    FreeDV has been EOL'd for some time.
    No current Avid product is supported on Vista or your graphics card.
    But, I've recently heard of people having the same issue if they have another video player app running when they launch Avid. (ie Windows Media Player)
    So to answer the question:
    no.
    MacPro dual 2.66GHz 2GB RAM NVIDIA GeForce 7300 GT Storage: 2TB G-Speed eS with controller card 2x500GB Hitachi SATA-II internals various external... [view my complete system specs]
  • Wed, Jan 23 2008 8:45 AM In reply to
    • camoscato
    • Posts 4,438
    • Points 53,005
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Lots of people have similar problems with video freezing, and while most of them seem to be solved by getting the right video card drivers installed, most of them are running XP, so if this is a Vista compatibility problem, then video card drivers may not be of any help to you.
    Here are the results of a forum search for "video freeze".  Hopefully something in there will help you.
    good luck,
    Carl
    MC 3.0, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 2 GB RAM, nVidia GeForce 7150M, Conexant HD Audio [view my complete system specs]
  • Sun, Apr 27 2008 7:13 PM In reply to
     The problem is your graphics card driver. I have an NVidia Q 1400. The same things happens to me if I use the latest "unsupported" driver but if I use an old "XP" driver all works ok.
