DQS
www.mpenyc.com
A workaround that I've used in the past on MC is to modify the clip source tape. Note, I haven't tried this on XP (or MC in years for that matter) but it should work.
Let's assume that your tape is from project XYZ, called tape 123, and you want it to be attached to project ABC. Click on the clip you want to change and choose Clip->Modify... Chose Tape source in the modfy options and click OK. You will now see all of the tape names associated with your project. Create a new tape name and call it 123. Select it and assign it to the clip, following the dialogue prompts.
So what's really happened here? The tape name that Avid uses (but doesn't display) can be regarded as XYZ:123. By changing it to the same name in the new project you've changed the name to ABC:123.
Good luck. Let us know if it works for you.
This is very worrying. Avid shouldn't do this at all. Dom's suggestion is the one to follow. Open each of your media folders and delete the .pmr and .mdb files and let Avid rebuild them. That should sort out your problem.
As an aside, you might like to check your media with MDV if you haven't already. This allows you to scan your media drives, ignoring Avid's database files. This should show you the correct project associations for all your media.
Lucas:
Yes, always use the media tool for deleting media. If at any time you launch the media tool and the window is empty, rebuild the database files. I would always recommend selecting current project rather than multiple projects at one time. The media tool allows you to delete both associated media files AND pre-computes you have created along the way - they eat up a lot of space as well. Select "current project", the appropriate drive(s), select all three display options and all of those files will be displayed for the project at hand.
Regarding shared media between projects, I always build a "Common Elements" project for shared footage, shared graphics, music, titles, effects, timeline templates, etc. Use open bins to retrieve this material in any local project. Later, when the local project and it's associated media and pre-computes are deleted, everything from "Common Elements" remains online.
Something's gone seriously off the rails here, Lucas.
If this were my system behaving this way, I'd wait for a reasonable working break then do a complete new clean install. That is either format the boot drive and reinstall Windows, or better still, get a new HD and install Windows to that. Then put back eveything needed and finally replace the project files. Let Avid rebuild the settings files.
The reason for installing to a new HD is not because I think that there's anything wrong with it. HDs are comparitively cheap, and by doing things that way you have a complete working, bootable backup should something go wrong. As a bonus, once everything is reliably working you have a spare backup drive.
And as to the question about media tool, I use MDV for that purpose because it seems to leave less behind. I prefer the way it handles "orphan" files too, and I find it faster when deleting a group of projects.
