Latest post Fri, May 2 2008 12:38 AM by the_dark. 6 replies.
Page 1 of 1 (7 items)
  • Thu, Jan 17 2008 10:02 AM
    • Mxpowers
    • Joined on Thu, Jan 3 2008
    • Posts 9
    • Points 125
    Video Playback Again
    Both video playback window will not display video.  It will play the sound but no video.  Now I had this problem about 3 weeks ago.  All I did was update the video and motherboard driver and it worked.  Then all of sudden it doen't work again. PLEASE HELP
     This is my system:
    Intel Core 2 Duo E6850 Conroe 3.0GHz
    2gb of ram
    NVIDIA nForce 680i LT SLI ATX Intel Motherboard
    GeForce 8800GTS 320MB 320-bit GDDR3 PCI Express x16 HDCP Ready SLI Video Card
  • Thu, Jan 17 2008 3:24 PM In reply to
    • camoscato
    • Posts 4,795
    • Points 57,245
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Video Playback Again
    Perhaps you have Automatic Updates turned on, and your drivers were automatically updated.  That's what I'd check first.
    good luck,
    Carl
  • Thu, Jan 17 2008 3:40 PM In reply to
    • pneumothorax
    • Joined on Fri, Mar 24 2006
    • Bulgaria
    • Posts 57
    • Points 690
    You should check your Quicktime version too. I've seen such an issue on a machine with enabled automatic updates of QT.
    MCA 2.7.2, HP xw8200, 2 x Xeon 3.4 GHz, 2GB RAM, Quadro FX1400 [view my complete system specs]
    Warp. Timewarp.
  • Sat, Jan 19 2008 8:23 AM In reply to
    • Mxpowers
    • Posts 9
    • Points 125
    camoscato:
    good luck,
    Carl
    My automatic updates is on but I have had it on for 3 months so I don't know why that would make a difference.  Also, I didn't update quicktime. So I don't see how that would be the problem as well.
  • Sat, Jan 19 2008 9:31 AM In reply to
    • camoscato
    • Posts 4,795
    • Points 57,245
      Moderator: Meridien
    Well, if Windows automatically updated your video card drivers, and the new ones are incompatible with Media Composer, that could cause playback problems.
    Similarly, if Quicktime is set to automatically update itself, and it did so without you knowing it did, that could cause playback problems.
    Since the system was working, and now it's not, and you didn't change anything, you have to look for things that changed without you knowing they changed.  Automatic updates will do that.
    good luck,
    Carl
  • Sun, Jan 20 2008 4:05 AM In reply to
    • Mxpowers
    • Posts 9
    • Points 125
    Ok thank you for clearing that up.  So then how do I guess go back in updates or something.
  • Fri, May 2 2008 12:38 AM In reply to
    • the_dark
    • Joined on Fri, Aug 17 2007
    • Posts 33
    • Points 400
    Mxpowers:
    Both video playback window will not display video.  It will play the sound but no video.  ...  Then all of sudden it doen't work again.
    We've battled this problem off and on for about a year. I think I finally have the cause - corrupt setting files. The key moment was when one of our students was ready to take a baseball bat to the system because the video playback was working when he started a new project but then suddenly no more video. Just frozen images. Rebooting wouldn't fix it. Power cycling the deck wouldn't fix it. Nothing, nadda. Then as a last ditch test I opened a different project, and "shock," the video was playing. Returned to his project and no video. Quit Avid, opened his project folder, deleted all *.avs files, restarted Avid, opened his project, and the video was working again. Glory be.
    For some reason Avid's setting files keep corrupting themselves, resulting in no video playback. It happened again today to another student. This time deleting the project setting file didn't fix it. But, deleting the user setting file did.
    I can't find any way to forcibly recreate the problem so I don't know how to report it to Avid. Maybe Avid should add some kind of setting file corruption test. And, if it discovers a corrupt setting file offer to delete it.
    In the meantime, try deleting your project setting and user setting files anytime video playback stops working.
    Charles
    Fifteen Dell Precision 390's Intel Core 2 Duo 2.4Ghz 2GB Memory 160GB System Drive 320GB Media Drive nVidia Quadro FX550 Five Dell Precision T7400's... [view my complete system specs]
