Latest post Sat, Jul 4 2009 9:16 PM by alaa329. 5 replies.
Page 1 of 1 (6 items)
  • Thu, Jan 10 2008 2:16 PM
    • Sam Eklund
    • Joined on Thu, Jan 10 2008
    • Posts 2
    • Points 30
    DekoCast 4.1x group composite style issue
    Why is the ability to use a clip as a mask for grouped objects disabled in 4.1x versions of the DekoCast SW?
    After a system crash on one of my DekoCasts with the 4.0x SW (where this functionality exists) I'm trying to recreate the scene on a 4.1.2 system with no luck. Using a still (Deko object) and moving it  works in 4.1.2, however I need more accurate masking than that for this application.
    Is it a bug or a feature, or maybe a Corsica Board issue?
    The 4.0x system is a Corsica SD only, and the 4.1.2 system is an SD / HD Hybrid
    We're working in SD PAL 16x9
    Anyone run into this, any solutions?
  • Wed, Jan 30 2008 7:57 PM In reply to
    • Teicia
    • Joined on Wed, Aug 16 2006
    • Red Bank, New Jersey
    • Posts 109
    • Points 860
    Re: DekoCast 4.1x group composite style issue
    Hi Sam,
    I spoke with the SQA department and there could be an issue between Targa-based systems and Corsica-based. But this is the same system right, just different versions of software?
    They asked me to have you phone into Broadcast Support to troubleshoot your finding. If it is a bug and can be fixed, they would like to log it into the system.
    Please contact Broadcast Support at 1-800-639-7364, choose 1, then 5 for On-Air Graphics support.
    Teicia
  • Sat, Jun 27 2009 7:21 PM In reply to
    • alaa329
    • Joined on Tue, Nov 21 2006
    • Posts 2
    • Points 20
    HI I AM WORKING ON ALDAWRII AND ALKASS SPORT CHANNEL - DOHA - QATAR
    I HAVE AVID DEKO CAST
    deko cast info:
    SN: 0020-03981-01 B
          ABACT639272
    DONGLE: 623037391
    BUT IM FACING A TROUBLE ITS WHEN STARTING THE DEKOCAST APPLICATION IT GAVE ME THIS ERROR
    Can't start Inflexion Engine : No hardware found . No canvases created
    So please if sombody can help cause the dekocast is used for a critical issues in our tv station
    Alaa Ghraizi
    Graphic Coordinator
    Al Dawri & Al Kass Sport TV Channel
    Doha Mob:+9745036197
    email :  alaa329@hotmail.com
  • Mon, Jun 29 2009 5:30 PM In reply to
    • Teicia
    • Posts 109
    • Points 860
    To help resolve your issue, please contact Broadcast Support...
    Avid Broadcast Support:
    Tele:   (800) 639-7364 or (978) 275-2484
    Press 1, then 5, then 1 for Deko
    Press 1, then 5, then 3 for DekoCast
    Press 1, then 5, then 4 for Thunder
    Thanks and good luck.
  • Mon, Jun 29 2009 5:55 PM In reply to
    It looks like you are in Qatar, so you should please contact your local support. This error indicates that the software is not detecting the I/O card (Corsica). Has anything changed recently or did this just suddenly happen?
    As a point of reference, when all OAG units are shipped, we include the Acronis program which can be used to back up and/or restore your system partition. We recommend that when after you install your system and everything is working to your satisfaction, please make a backup of the system partition at that time. Then if a problem occurs at a later date, you can always restore to this known good state.
    If you did not make a backup, we also ship an image of the system in teh E:\System_restore folder. You can use Acronis to create a bootable media disk. And then before restoring that original backup, I always recommend making a backup of the current system - just so that you can at least restore to the current state.
    Once you have created a bootable rescue disk, boot off that. Then navigate to the E:\System_restore folder and restore either your backup or the default image.tib. The default does NOT have any software loaded. So aftter rebooting, you will need to go through the entire new system installation process. I recommend NOT activating Windows until after you are sure the restore will actually "fix" youyr system.
  • Sat, Jul 4 2009 9:16 PM In reply to
    • alaa329
    • Posts 2
    • Points 20
    Actually this error appears many time when running the dekocast app in the past few months and in that time i made retore to the dekocast system and it works prop .
    but now when i made restore the dekocast apllication never run and all the time its giving the same error msg..
    So i dont know if the corsica board is working any more
