Latest post Fri, May 2 2008 10:09 AM by mark.burton. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Dec 30 2007 5:50 AM
    Record sequence time code onto DSR11?
    Two part question, the first one being the most important...
    I'm trying to finish a low budget feature going to a DI that's made up of seven sequences (reels), each with a different hour time code. I need to record DVCAM reference tapes for each reel, where the vitc matches the viz tc. It's a 24 frame film project captured from PAL DVCAM sources. Is it possible to record the sequence time code during digital cut to a DSR11 (connected through FW port on my G5 - no Mojo or expansion card)? I only have raw, non-striped dvcam stock and don't care about the accuracy of the first part of the recording since it's just bars, slate and leader. The only info I could find was on a Liquid Pro thread - it suggested this could be done, but the settings don't apply to my MC. I've tested crash recording, local and remote, and the tc either starts from 00: or jams any preexisting time code that was on the tape.
    Secondly, is the FW port on the SDI mojo functional? I had problems outputting with mine before I just disconnected it. I haven't heavily researched this, but heard there seems to be some issues with just it and not the analog Mojo.
    Thanks.
    MC 2.8, Mojo-SDI, G5 Quad, 2.5 ram
  • Mon, Dec 31 2007 1:23 AM In reply to
    Re: Record sequence time code onto DSR11?
    I think I've discovered the answer for my first question, which involves changing a ext tc menu setting. Unfortunately, I've never used a DSR11 before and was given this deck without the remote, which seems to be the only way to access the menus. Does anyone know if there's a way to access the menu list without the remote?
    As to my second question about whether the FW port functions on the SDI Mojo (like it does on the basic Mojo), if anyone knows - yes/no - I'd appreciate it. I've found some threads here and there without a solution and time forced me to workaround and move on. If yes, at least it'll be worth researching more.
    Thanks.
  • Mon, Dec 31 2007 10:58 AM In reply to
    • tobyjt
    • Joined on Sun, Sep 2 2007
    • England
    • Posts 163
    • Points 1,950
    As far as I know, you can't record sequence time over firewire, you need RS-422 deck control..... that's from my experience.
    Toby
    HP Dual Xeon XP Pro Workstation 'turnkey' Nitris Symphony / DS workstation / MacBook Pro Media Composer 3.1 OS X Tiger 4GB RAM/ Unity Lanshare... [view my complete system specs]
  • Tue, Jan 1 2008 6:47 PM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    OK, first things first. You will need the DSR-11 remote to do this, its the only way to get to the menu options unfortunatly.
    Now the way this works is to prestripe the DVCAM tapes with the timecode you need and then have Avid lock to this TC. This is not simple with the DSR-11 since its quite a low end deck and so very few TC features are included.
    I spent some time trying to figure this out a few years ago and here is the solution I posted at that time. It should all still work, but I haven't tested it for some time:
    Its seemingly impossible to stripe a new TC such as 00:58:00:00 or 01:58:00:00 to a DVCAM tape with the DSR-11. Here is one solution. NOTE - You will need to connect the DSR-11 directly to the Mac via firewire (i.e. not via a Mojo)
    • Download SimpleVideoOut from the Apple (its free):
      http://developer.apple.com/samplecode/SimpleVideoOut/index.html
      (If you are on an Intel Mac use the app titled 'SimpleVideoOut X' as this is the Universal build. Otherwise use the CW one. If you have trouble getting the X one to load, then you may need to build the app again from the included XCode project)
    • In Avid, export a 60 second black DV PAL (or NTSC) QT Movie. Just export a black title from the video track to a self contained QT (not a ref QT). Do NOT use Avid DV codec.
    • Load this QT movie into Sebsky Tools and change the TC to what ever you want the TC to start at on the tape, for example 00:58:00:00 just make sure its before the point you want to drop in at, but no more than 60 seconds before.
    • Then load this DV QT movie into SimpleVideoOut (having selecting Firewire / Apple Firewire PAL or NTSC when the dialogue pops up).
      Now load a fresh DVCAM tape and using the remote, set your DSR-11 to:
      REC MODE = DVCAM
      DV IN TC = EXTERNAL
      (Have the TC display turned on for this first test so you can verify it has worked.)
      Then just hold the REC and PLAY buttons together on the DSR-11 and press play in the SimpleVideoOut app and the new TC will be recorded to your DVCAM tape.
    • Remember to turn 'DV IN TC' back to INTERNAL on the DSR-11 when you come to record your Avid edit to tape.
    The problem with the DSR-11 is that it is not the best deck when it comes to starting recording at the exact TC, but playing with the pre-rolls should eventually get it spot on.
    Good luck with that. Once you've done it once you'll have all the apps you need and the dummy black QT movie can be re-used by just altering the TC in Sebsky tools.
    With regard to the Mojo SDI and firewire, be aware that its 4 pin DV port operates quite differently from the original Mojo. It is a passthrough port and the only way to use it when inside Avid is to (strangely enough) turn the Mojo off via the DNA button in the timeline. Then the system will just see the Mojo as a firewire extension cord to the deck and present capture options ect.
    Having said that, when I last tested the Mojo SDI with Xpress Pro and a PAL 24p project, I found it was not very reliable. That was when it first cam out though (v5.5 I think) so things may have improved.
    You might try just taking the Mojo SDI out of the equation all together for the DSR-11 layback.
    Good luck
    Mark
    MacBook Pro 2.16 , G5 Dual 2.0 , MC 3.0.5 [view my complete system specs]
  • Thu, May 1 2008 7:28 PM In reply to
    • esqueleto
    • Joined on Mon, Apr 17 2006
    • NYC
    • Posts 11
    • Points 105
    Hi Mark:
    All of this is good and has worked for me previously, but now I can't get Simple Video to run.  It gives an error message "Attempting to get exclusive access to hardware failed.  Doh."  This some thing happened in 2006.  I posted then and hbrock helped by suggesting that the Mojo should be taken COMPLETELY out of the system.  It worked for me until now.
    The Mojo is completely out, not connected to the Mac at all.  In fact I have disconnected all other FW devices.  I have the DSR-11 connected to the Mac by FW using an adapter to change from 4-pin to FW400.  DSR-11 is on, tape is in or out, tried SimpleVideoOut X CW as well as SimpleViedoOut 9 (the one that worked for me previously) per your instructions.  The Mac has been restarted numerous times after every change of config.  I was just going to Pre-black a couple of boxes of tapes.  It's a good thing I still have one left from the last time I did this.  Thank you for any help you can give me.
    /bob luke
    Avid Xpress Pro 5.8.0/OSX 10.4.11/Dual 2.5 GHz PowerPC w/2.5GB DDRS SDRAM/LG L1951,Viewsonic VX924,Sony PVM 14-L1/NVIDIA GeForce 6600LE/SIIG FireWire 800... [view my complete system specs]
  • Fri, May 2 2008 10:09 AM In reply to
    • mark.burton
    • London, UK
    • Posts 550
    • Points 6,835
    Looks like something has broken in SVO or changed in Quicktime. There were some pretty major changes in Quicktime 7.2.1 which may be responsible for this. I get the same error on my 10.5.2, QT 7.4.5 system.
    You could report it on the Quicktime developer mailing list and hope an Apple dev picks it up, or alternatively fill in a bug report (free ADC account needed):
    http://developer.apple.com/bugreporter/
