Latest post Mon, Jun 9 2008 1:28 PM by ibayerl. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Dec 17 2007 5:25 AM
    • Rock007
    • Joined on Thu, Oct 20 2005
    • New York
    • Posts 28
    • Points 330
    CRAZY PIP Jitter!
    Having this Picture-in-Picture jitter issue---not a new issue but just so sick of having it.  Anyone have a solution.  When the picture moves any which way---it jitters!  Doesn't matter how fast or slow you make it---it just won't stop.  Please tell me that someone has found an AVID solution to making pictures float on and off screen NICELY?!?!? HELP!
    Microsoft Windows XP Professional Version 2002 Service Pack 2--Dell Dimension 9100 [view my complete system specs]
  • Mon, May 19 2008 12:52 PM In reply to
    • ibayerl
    • Joined on Tue, Oct 23 2007
    • austria
    • Posts 7
    • Points 75
    Re: CRAZY PIP Jitter!
    I'm having the same problem and would be thankfull if anyone has a solution.
    thanks
    mediacomposer 2.5.3 on HP XW8200 [view my complete system specs]
  • Mon, May 19 2008 1:47 PM In reply to
    • NDLC21
    • Joined on Tue, Jul 3 2007
    • Posts 28
    • Points 410
    Are you using keyframes to move the pitcure ?
  • Mon, May 19 2008 4:09 PM In reply to
    Are you by any chance watching an interlaced program on a progressive monitor?
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Mon, Jun 2 2008 2:48 PM In reply to
    • ibayerl
    • austria
    • Posts 7
    • Points 75
    Yes i'm using keyframes.
    @"Job ter Burg":no i'm watiching the clip on a broadcast monitor that does fine with interlaced material.
    The jitter doesn't concern the fields, it's just the movement of the videolayer itself is jerky/jittery.
    I'm wondering if I'm doing something wrong or if MediaComposer can't render the movement smoother.
  • Mon, Jun 2 2008 3:48 PM In reply to
    • SoHo
    • Joined on Mon, Jun 2 2008
    • Posts 1
    • Points 15
    The solution is simple.
    Add another effect onto the PIP.
    For example (since all avid types have that effect) drag (with alt) the color correction effect (under image) onto your PIP.
    Don't adjust it, just render and it will do the trick.
    I usually add a timewarp (without adjustments) to solve it.
    Filed under: , ,
  • Mon, Jun 9 2008 1:28 PM In reply to
    • ibayerl
    • austria
    • Posts 7
    • Points 75
    Hi SoHo,
    I tried your solution but sadly it didn´t improve the quality.
    but maybe I have found the cause of the issue. The material I captured was recorded as progressiv and the project I´m working in is interlaced.
    could this be the cause of my problem?
