Latest post Wed, May 21 2008 3:09 PM by Larry Rubin. 8 replies.
Page 1 of 1 (9 items)
  • Mon, Dec 17 2007 4:28 AM
    • Bauhaus
    • Posts 2
    • Points 30
    "Hardware detected a host vsync error"
    Hi Everybody,
    I'm getting the following error in the console.
    Does anyone know what this might be?
    I'm running an Adrenaline with an HP 8200 MC2.7.5 XP
    My picture is stuttering and tearing. This happens at random.
    I tested the Adrenaline on another system and it works fine. I tested
    the problem system with different projects on the Editshare and it
    shows the same problem.
    Does anybody have any ideas?
    Thanks for your help.
    Eric
  • Mon, Dec 17 2007 12:21 PM In reply to
    • Ruurd
    • Joined on Mon, Dec 17 2007
    • Amsterdam, Holland
    • Posts 3
    • Points 45
    Re: "Hardware detected a host vsync error"
    Hi Bauhaus,
    Is de Adrenaline box connected to the onboard Firewire or to a PCI firewire card.
    greetz,
    Ruurd.
  • Mon, Dec 17 2007 4:13 PM In reply to
    • Bauhaus
    • Posts 2
    • Points 30
    Hallo Ruurd,
    I'm using the internal firewire on the HP xw8200. It has been working fine until now.
    Bedankt,
    Eric
  • Thu, Jan 3 2008 10:41 AM In reply to
    • Ruurd
    • Posts 3
    • Points 45
    I,ve had the same problem but in an Unity fibre channel environment (whit LP and EX Media array's) with diverent hp's. only the wx8200 has this problem. Avid suggested to connect the BOB to the internal FW and check the
    Avid® Adrenaline™ Configuration Guidelines for the HP® xw8200 Workstation
    . When I'll find out more about it or hear anything from Avid I'll let you know.
    For now you can try to work standalone, I found out when I consolidated a sequence to a local drive I was able to write it back to tape without any problems.
    Greetz
    Ruurd.
  • Thu, Jan 3 2008 3:28 PM In reply to
    • mvegas
    • Posts 1,195
    • Points 13,685
    Check to see if the Ref light is lit on the front of the DNA box.  If it is not and you syncing the
    DNA box with a black burst source, make sure you set the genlock to reference and not
    the default Internal
    HTH
  • Wed, May 21 2008 1:44 PM In reply to
    • Aldebaran66
    • Joined on Tue, May 13 2008
    • Netherlands
    • Posts 5
    • Points 45
    Thanks for the important information.
    - The ref light on my DNA-box is not lit.
    - I connected the refs of DNA and recorder to a G2-Evolution.
    - What do you mean by 'genlock'? Where can I set the genlock to reference? The setting Audio Project - Hardware - Sync mode - Internal cannot be changed.
    AGB,
    The Netherlands
    Avid Media Composer Adrenaline [view my complete system specs]
  • Wed, May 21 2008 2:40 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,574
    • Points 78,535
     Go to your video output tool and you'll see a button for sync lock  - choose reference and your DNA will lock to an external genlock reference signal.
  • Wed, May 21 2008 2:51 PM In reply to
    • Aldebaran66
    • Netherlands
    • Posts 5
    • Points 45
    Hi Larry,
    Thanks a lot. Wow, the ref-light is burning! Never seen that.
    Have a nice day!
    Allard Bon,
    The Netherlands
    Filed under: ,
  • Wed, May 21 2008 3:09 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 6,574
    • Points 78,535
     You're welcome, Allard. Glad that worked out for you.
