MichaelP:I have been working with several of the engineers at RED to create better workflows as things move forward. Something to keep in mind is that no one is editing the native R3D files for actual projects as the performance is not quite up to par for editor expectations. So, in all cases, Avid or FCP, a proxy is created - be it DNxHD or ProRes. So that part of the process is a wash. What becomes more interesting is the metadata management for the files regardless of how you choose to finish. Avid has far better metadata management. Currently users are having to add the scene/take information to the filename since you cannot lose that for a conform back the files. Since Avid tracks file names in a separate column; editors can actually change the name of the clip to something succinct and useful like... 24A/3. It has already been said that RED will be releasing the SDK of the R3D files to other manufacturers after NAB. So things will change again, and all for the better. By the way, you can run metacheater on a PC.. what problems are you having? Michael
Michael
Gosh, I can run Metacheater on PC? I could have SWORN the Red>Avid workflow afforded by Metacheater was only available on a Mac. Based on my readings of the Reduser posts. But maybe it's because of the fact that RedCine does not yet export any metadata, making a PC workflow using Metacheater moot? I have never used Metacheater, but would love to start if there's actually a way to do this entirely with RedCine and a PC. Have I missed something big here?
And further to your point re: FCP and Avid both requiring renders of Red proxies (whether DNxHD or ProRes), it's true. Everyone I know with the most tricked out FCP system is not cutting r3d natively with any success. I'm very excited to see how Avid's inherent strengths will make my Red workflow as easy and effective as any other NLE, if not more so.
EDIT: I see that the coders of Metacheaters have released an updated version of Metacheater that is PC compatible. But I think I still need access to a Mac to run RedAlert to generate the files with metadata/timecode, correct?
Red, shmed. This was shot with a cell phone: http://vimeo.com/1649221 Edited in Avid.
Metacheater can run on both mac and pc.
You need a mac based Avid to get RED files into the Avid because the quicktime plugin only works on the mac side.
You can export quicktimes out of Redcine and then import into Avid but that takes a lot of time. Also, getting Redcine to work without bugs takes a lot of work.
I cut a feature back in December that was shot on the RED camera and I cut it in Avid Media Composer. I used a Mac based Xpress Pro to import and then moved the files over to our PC based MC. Had no problems.
If you have any questions ask away and I will try and answer them as best as I can.
Thanks Buck50.
That's what I thought: I need a Mac somewhere in the chain to make use of Metacheater in a Red workflow.
You can bet I'll have a couple questions for you, though. Cheers.
Hi, Here is an idea... I am right now editing a short film shot on the RED ONE. Being an avid editor i don't like to have to resort to any other software to do my thing so after some trial and error i came up with a use full if not super fast solution. Here we go! First up. I'm editing on my old macbook 2Ghz with 2GB of ram. Media Composer V3.0 and i have the RED codec installed. It's a good thing I'm on a mac since Steve Jobs and the guys at apple at some point came up with the idea that automater might be a practical thing. And it is! I made a scrip that from the RED hard drive makes an ALIAS of all the xxx_xxxxxx_xxxx_M.mov files to one folder. Once all _M.mov files are in one folder I then can with METACHEATER open them. From METACHEATER i can then export an .ALE and import that into my Media Composer, and in one move preserve all my METADATA. Whats left then is just to batch import all my quicktime files, and I have found out that you can just use the ALIAS files used to make the ALE in METACHEATER. This way you just have to do a backup of you RED drive to, what i like to think of as my edit drive, run one automater script, that when completed opens up METACHEATER. Open QTALIAS, Export ALE, Import ALE and Batch Import QTALIAS - EASY! And the best this is that you can import in AVID to any resolution or file format you like. Omf, MXF, HD, SD it doesn't matter. The only thing that i still don't like about this proses is import time - It's like 10 times real time, but I my mac is old and slow, guess that on a new mac pro or macbook pro it will go a lot faster. If anybody would like to do the same, i would love to hear from you and get feedback.I have made a short white paper get it here nielsostenfeld.dk/red/red2avid.pdfThe film will premiere late September in Los Angeles. niels.ostenfeld@gmail.com
Here is an idea...
Excellent. You have created half of an upcoming solution that demoed a few months ago. We are waiting for RED to finish beta 16. It basically is an Automater that uses some new feature in Redline to recreate new QT proxies and an ALE automatically with more metadata than via MetaCheater - both timecodes, color parameters, etc. I am hoping to see this get out in the next 2-3 weeks.
I'd like to hear more about that if possible. Nice to have a reply that proves I'm not insane :-)
As I see Jim Jannard announced that Avid is working on native r3d support:
Here
Is there any confirmation? If yes, when should we expect it?
...and what happens if I press this button?...
Features are never announced before they are released.
Discussing when is considered speculation, which is a violation of the Community's TOS.
