Latest post Wed, Sep 3 2008 10:33 PM by mangamanga. 1 replies.
Page 1 of 1 (2 items)
  • Thu, Nov 15 2007 8:49 PM
    • Dynastol
    • Los Angeles
    • Posts 75
    • Points 910
    Exception: Video SIgnal present but not captured
    I just upgraded from Xpress DV 3.5 to Xpress Pro 5.7.5. I am trying to capture HDV footage through firewire into a 1080i/59.94 HDV project but I always get the error message "Exception: Video Signal present but not captured.". The only way to get footage in is by digitizing on the fly without timecode, so batch/digitizing is impossible.
    I have tried digitizing from two different cameras, Sony's Z1U and Canon's HV20, both with the same result.
    This is what the console has to say:
    unit type = UNIT_TYPE_VIDEO_CAMERA
    AUTOCONFIGURE Firewire NODE 1: Device ID does not match, trying to match family code...
    AUTOCONFIGURE Firewire NODE 1: Device code '' not matched to machine.
    Audio sample rate of incoming media is marked as 48000
    The default render wait time is 50
      Capturing master clip :: Test 3 Bin.01
     Discontinuous TC base tolerance = 6
    Exception caught in APlayer::Play - Exception: DIOProducer - digital I/O missed starting timecode
    Channel: Channel not configured.
    Exception:
    @ Thu Nov 15 12:19:23 2007
    No frames recorded.
    ***** Capture Failed *****  Clip Discarded
    Exception:
    @ Thu Nov 15 12:19:24 2007
    • Exception: Video signal present but not captured.
    Exception:
    @ Thu Nov 15 12:22:07 2007
    • Exception: ADVAudioDev: DV device missed starting timecode
    I am running Avid Xpress Pro 5.7.5 on a Mac Book Pro 2.33 GHz Intel Core 2 Duo with 2 GB 667 MHz DDR2 SDRAM and an ATI Radeon X1600 graphic card. ... [view my complete system specs]
  • Wed, Sep 3 2008 10:33 PM In reply to
    Re: Exception: Video SIgnal present but not captured
    Maybe a bit late but still wanted to add advice for future help seekers.
    This problem is related to preroll issues. In the capture window, set preroll to custom preroll and give it 10 sec (try less if it works).
    If your tape starts at zero, bad luck, you may have to let go of the first few seconds of the tape or copy the beginning to another tape with more preroll time.
    Also, if your tape has many TC drop outs and you don't need the TC for editing, you may uncheck the TC button un the uper button row (very right of V/A1/A2 etc.)
