Latest post Wed, Nov 14 2007 8:06 PM by jweis. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Oct 28 2007 8:00 PM
    • Mercedes
    • Joined on Fri, Mar 31 2006
    • Dublin, Ireland
    • Posts 57
    • Points 615
    Check in all open bins - Interplay limitation
    In the Limitations for Interplay the following appears:
    Selecting Check In All Open Bins from the Fast menu in the bin might not check in the open bins.
    Workaround:  To check in all open bins, Select Check In All Open Bins from the File Menu.
    My question is this:  Check In All Open Bins appears in the Bin Menu and in the File Menu you get: Check In Open Bins In Project.
    Which is the workaround??  Help?
    Mercedes
    Client Operating system : XP pro SP2 Client Avid version : 3.1.1.1 QT 7.5.5 Adrenaline Sys info: CPU :xw8200 4GB ram Interplay 1.5 ISIS 2.0.1... [view my complete system specs]
  • Mon, Oct 29 2007 7:07 PM In reply to
    • felipousis
    • Miami, FL
    • Posts 532
    • Points 5,600
      Moderator: Spanish Language
    Re: Check in all open bins - Interplay limitation
    Mercedes: apunta a lo mismo, chequear todos los bins abiertos del proyecto...
    Saludos!
    Custom Mac Pro OSX 10.8.5 | Windows 7 Pro 64 | ProTools HD Software | Focusrite Saffire Pro 40 | MBox 3 | UAD Quad PCIe | JBL LSR 305 | Universal Audio... [view my complete system specs]
    Felipe Gonzalez A.
    Recording Engineer/AES member.
    Avid ACSR Elite
    http://felipousismix.wix.com/felipousismix
    https://soundcloud.com/felipegonzalez-1-1/tracks
  • Mon, Oct 29 2007 10:56 PM In reply to
    • Mercedes
    • Dublin, Ireland
    • Posts 57
    • Points 615
    Hi Felipe,
    unfortunately in spite of my name I don't speak spanish!
    Can you translate please?
    Mercedes
  • Tue, Oct 30 2007 4:18 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,320
    • Points 25,875
    the translation is:
    In English:
    it aims at the same, to check all bins open of the project.
    So many systems, so little space. So... everything Avid and a Hyundai Veloster Turbo. [view my complete system specs]
  • Tue, Oct 30 2007 6:05 PM In reply to
    • Mercedes
    • Dublin, Ireland
    • Posts 57
    • Points 615
    Thanks for the translation Jeff!
    To be clear - as long as you don't use the Check In All Open Bins from the burger/fast menu in the actual bin - can you safely use either -
    Check In All Open Bins from the Bin Menu
    OR
    Check In Open Bins In Project.from the File Menu
  • Wed, Nov 14 2007 7:19 PM In reply to
    The File and Bin menu commands are equivalent, and are correct workarounds for the fast menu problems.
  • Wed, Nov 14 2007 8:06 PM In reply to
    • jweis
    • Joined on Thu, Aug 17 2006
    • Posts 23
    • Points 205
    You can right-click inside a local bin and select “check in all open bins to Interplay”, or the menu item “check in all open bins to Interplay” from the main “Bin” menu.
    You currently cannot use the fast menu (hamburg icon) for the check-in in early Interplay versions. This defect was adressed in version 1.1.5.
