ServerUnity V5Station1Macintel 2x2.66ghz, 3GO ramMC 2.7.5Fibre Celerity FC-41ES - driver version V3.0Adrenaline model 0x1, 0x14001fibre manager v5.0 (2140)Station2Macintel 2x2.66ghz, 3GO ramMC 2.7.5Fibre Celerity FC-41ES - driver version V3.0Mojo analog rev Dfibre manager v5.0 (2140)
DQS
www.mpenyc.com
If you use the ATTO Configuration tool to upgrade the firmware on the ATTO Fibre Channelhost adapter board, the Connection Mode setting reverts to the default setting of AL(Arbitrated Loop).Workaround: To correct this, you must reset the Connection Mode parameter in theConfiguration tool to PTP Preferred.To reset the Connection Mode setting:1. Do one of the following:t (Windows) Click the Start button, and select Programs > ExpressPCI ConfigurationTool.t (Macintosh) Navigate to the folder where you installed the ATTO Configurationtool, and then double-click ATTO Configuration.app.The ATTO Configuration tool opens.2. In the Device Listing window, navigate to the appropriate channel on your host adapter.The NVRAM Configuration tab opens.Limitations313. Click the Connection Mode menu, and select PTP Preferred.4. Click Commit.n You must restart your system for the change to take effect.
i have the same problem.... and i d'ont understand...
The message is (in the file attachment) :
FIBRE MANAGER : LOST CONNECTION TO SERVER
Read my post...
http://community.avid.com/forums/t/53971.aspx?PageIndex=1
It's strange and not good ....
Not thanks for avid team because my problem has lasted for 9 months....
"is there anyother way of checking the integrity of an installation?"
1) Hire an Avid ACSR to check the hardware/software setup.
2) Hire a Fiber Cable Contractor to check your cables. They have specialized meters to evaluate fiber cables.
christopher@fearlesstv.com:I have just seen that avid has produced a white paper on fibre cables. In it, is mentioned that using the wrong cable or even unrolling the cable badly can lead to all sorts of problems such as disconnections and inability to find files etc.
Yes, and your warranty will be null and void and you will perish poor in the Unsupported Land.
Avid also likes to talk about 'corrupt files', please make sure you check for those.
Randall L Rike:2) Hire a Fiber Cable Contractor to check your cables. They have specialized meters to evaluate fiber cables.
That's a thousand bucks right there.
Just hire a freelance ACSR to check for you.
Common things to check --
FC Switch (both the software config and general hardware integrity). Sometime people mistakenly connect a client in a storage port on their FC switch.
tipping of fibre (try using another port or running a direct line to the switch)
see if you have any errors from Monitor Tool
I updated one of my adrenaline in version Leopard 10.5.3, MC 3.0, Fibre Connection 5.1, driver atto, etc..
and i have aways the same problem.
FIBRE MANAGER CONNETION LOST.
It's a big problem for my shared project...
i would like help but for avid team, this problem is very complicated.
bengo82:i would like help but for avid team, this problem is very complicated.
You should then contact Avid directly. The forum is really intended for user to user help.
I would start by doing a clean install if possible.
I had that problem for a while in two different systems (Mac and Pc). Both were the Atto announcing their own death. One day they simply stop working. Once substitued, everything was fine.
Hope it helps.
We are having the same issue with Unity 5.1. Any answers from Avid?
