Latest post Tue, Apr 22 2008 4:45 PM by TCurren. 4 replies.
  • Wed, Oct 24 2007 5:49 AM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 210
    • Points 2,620
    Is decompose busted?
    I have found that when I do a decompose of the final sequence of an offline, from sd to HD, many stills are being substituted for other stills in the sequence.  This has made a batch import of stills basically useless.  We noticed on an Adrenaline a few versions ago.  And now on a SN 1.7.2.
    The decompose was done as Both Video and Imported files, 60 frame handles.
    Any ideas?
    Jef
    PC - Dell 360 3GHz XPPro 2.5 GB ram, local SATA st [view my complete system specs]
  • Wed, Oct 24 2007 8:18 AM In reply to
    • TCurren
    • Posts 887
    • Points 11,390
    Re: Is decompose busted?
    We never decompose imports. It will really screw you on QT movies. Just batch import straight. It's not like you are going to bring a still in for too long a duration, so why do it?
    Terence Curren Alpha Dogs, Inc. Burbank, Ca www.alphadogs.tv
  • Wed, Oct 24 2007 6:19 PM In reply to
    • jef
    • Maryland
    • Posts 210
    • Points 2,620
    Well,  in the light of day after a long night, I was talking about this with some of the other editors.  They said, "Yea, that broke a LONG time ago."
    You are right,  I don't really need to for most stuff.  But on this show I have some LONG QT files.  And the import are taking a long time for the complete files - of which I am not using all.  So there is a lot of wasted time.
    This is first time I have run  into this, so it surprised me.
    Jef
  • Mon, Apr 21 2008 11:39 PM In reply to
    • Lord-Q
    • Los Angeles
    • Posts 16
    • Points 160
     We have the same issue, Its a huge problem when we have lower third banners and it changes the name of the imported clips. A work around is to decompose captured clips first and then decompose Imported clips only.Dont use the captured and imported clips option. That seems to work
    Avid Editor DS Nitris:Symphony:Media Composer
  • Tue, Apr 22 2008 4:45 PM In reply to
    • TCurren
    • Posts 887
    • Points 11,390
    Lord-Q:
    Unless.... The offline editors gave the imports a tape name. Many do that for tracking purposes. If that happens, even with "imports" unchecked on the decompose, your imports will get decomposed.
