Latest post Mon, Oct 22 2007 7:23 PM by CliveSmith. 3 replies.
  • Sun, Oct 21 2007 11:07 PM
    • myavid
    • NYC
    • Posts 29
    • Points 335
    Decompose MXF Sequence
    I want to save disk space. Is it possible to decompose an MXF Sequence in order to keep only the portions of footage used in the sequence on my hard disk? The footage was captured on P2 cards and Firestore.
    Avid Express Studio HDDell Precision Workstation 670Dual, 3.2GHz, Intel Xeon, 800FSB, 1MB L2 Cache5.0GB DDR2 ECC SDRAMnVidia, Quadro FX 3400160GB SATA... [view my complete system specs]
    What is weed? A plant whose virtues have not yet been discovered. - Emerson
  • Mon, Oct 22 2007 1:22 PM In reply to
    • CliveSmith
    • Joined on Thu, Jun 22 2006
    • South Africa
    • Posts 306
    • Points 3,620
    Re: Decompose MXF Sequence
    Decompose is not what you want.  Select your sequence and right-click select consolodate.  Set your handles, then select "delete original media" and that should do it.
    Remember that if you digitised anything that is not used in your sequence that you consolodate, this media will remain and you would need to manually delete that media as well.
    Be warned, though...  make certain that you are not trashing anything used in other sequences as well.
  • Mon, Oct 22 2007 4:37 PM In reply to
    • myavid
    • NYC
    • Posts 29
    • Points 335
    Thanks Clive. I will try your advice.
    Can I consolidate more than one sequence at a time?
  • Mon, Oct 22 2007 7:23 PM In reply to
    • CliveSmith
    • South Africa
    • Posts 306
    • Points 3,620
    Yes - just select the sequences and go through the same routine.
