Latest post Fri, Sep 28 2007 12:20 AM by Red Ochre. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Sep 23 2007 6:36 PM
    • TheGenius
    • Joined on Tue, Dec 12 2006
    • Maryland
    • Posts 53
    • Points 765
    xl2 24p pulldown and avid
    So I shot in 24p and used the 2:3 pulldown..i am attempting to digitize my footage and the error I am recieving is that i can't import video and audio unless the audio sample pulldown is selected but it then tells me its not supported when I attempt to select it..
    can someone please instruction on how to go around this and can someone please tell me my footage isn't lost...
    appreciate the help in advance
    "love, live life & Music..."
  • Sun, Sep 23 2007 7:33 PM In reply to
    • camoscato
    • Posts 4,650
    • Points 55,450
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: xl2 24p pulldown and avid
    What version of Media Composer?  Adrenaline or software only?  What type of project?
    good luck,
    Carl
  • Sun, Sep 23 2007 7:42 PM In reply to
    • TheGenius
    • Maryland
    • Posts 53
    • Points 765
    i have media soft..
    and i created the project as a 24p project...(should i of created it as a 30i?)
  • Sun, Sep 23 2007 8:16 PM In reply to
    • camoscato
    • Posts 4,650
    • Points 55,450
      Moderator: Meridien
    TheGenius:
    I'm not an expert in this by any stretch of the imagination, but based on this post, I'd give it a shot.
    good luck,
    Carl
  • Sun, Sep 23 2007 8:33 PM In reply to
    • TheGenius
    • Maryland
    • Posts 53
    • Points 765
    lawd..
    like that confused me more...
    what im getting from that is that seeing i shot in 24p (standard, 2:3 pulldown) i will have to create a 23.97 project and have to use the camera to capture my footage..
    i will try and see...but if anyone have a simpilar breakdown for a novice it would be great..
  • Mon, Sep 24 2007 3:09 AM In reply to
    • camoscato
    • Posts 4,650
    • Points 55,450
      Moderator: Meridien
    Answered in this post.
  • Mon, Sep 24 2007 11:12 PM In reply to
    • Red Ochre
    • Joined on Fri, Jan 27 2006
    • San Francisco
    • Posts 218
    • Points 2,775
    The point of 2:3 pulldown is that you can edit 24p in a 29.97 project, so that could well explain why you're having problems in a 24p project.
    MCA 2.7.2 (PC) and mojo MC 3.0 (mac) [view my complete system specs]
  • Wed, Sep 26 2007 8:14 AM In reply to
    Uhm.....not really. The point of pulldown is to have 24p sources live in a 29.97 environment.
    And the whole idea of a 24p / 23.98p NTSC project is that one can remove that pulldown. Remember Film Composer?
    Symphony Nitris 3.0 on 2xquad core XW8400/4(??)GB | MC 3.0 on dual core XW8400/3GB | Mojo SDI | Unity Lanshare 4.23 fibre | MC 3.0 on MacBook 2.16/2.5GB... [view my complete system specs]
  • Wed, Sep 26 2007 10:47 PM In reply to
    • Red Ochre
    • San Francisco
    • Posts 218
    • Points 2,775
    And if you edit 24p in 29.97 and output back to 24p are they still "living" in 29.97? Seems like a semantic point. Perhaps I'm not fully gasping the distinction you're trying to make.
  • Thu, Sep 27 2007 1:07 AM In reply to
    If you edit 24p footage in 29.97 you are bound to break the pulldown cadence, so it will not be as easy to remove that pulldown, if you would ever need to end up with a true 24p master (say for filmout, international delivery or an HD master).
    The whole idea about 23/24p projects is that you are able to cut 23/24p natively, and then (if necessary) add the pulldown upon playout. It has worked that way for decades, and it is generally a very wise workflow to choose. 24fps film is transferred - with pulldown to 29.97 video. Those tapes are captured in a 24p project, removing the pulldown during capture, enabling you to cut 24p natively. Pulldown is only added on the NTSC outputs.
    So in that sense 3:2 pulldown is not "meant" for editing 24p footage in a 29.97 environment, but that pulldown is meant for NTSC distribution. It's not a semantic distinction, it is a theoretical one.
  • Fri, Sep 28 2007 12:20 AM In reply to
    • Red Ochre
    • San Francisco
    • Posts 218
    • Points 2,775
    Makes sense.
