Latest post Thu, May 29 2008 2:16 PM by JoeProcopio. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Sep 7 2007 8:19 PM
    • JoeProcopio
    • New York City
    • Posts 310
    • Points 3,810
    Exception: MVL_INSUFFICIENT_SPACE
    anyone see this?  trying to capture to unity space...plenty of storage available...1:1 SD.  only adding space to the destination workspace makes it go away....
    1-DS/SN Nitris 8.4 QFE 1/3.0 xw9300 10TB local 1-SN Nitris 1.8.3 xw8200 10TB local 1-MCA 3.0 xw8600 dual quad 2-MCA 2.8.3 xw8400 quad 2-MCA 2.8.3 xw8200... [view my complete system specs]
    Joe Procopio Broadway Video AVID|DS Artist AVID Tech
  • Fri, Sep 7 2007 9:29 PM In reply to
    • Scott Carnegie
    • Winnipeg, Manitoba
    • Posts 950
    • Points 11,530
    • Moderator: Avid Symphony Nitris
    Re: Exception: MVL_INSUFFICIENT_SPACE
    Are you doing a batch digitze? If so, make sure the timecodes are correct and you don't accidentally have a clip that is 23 hours, like 02:10:10:00 - 01:10:10:00. I've had that happen on occasion :) Check the duration bin heading to see.
    :: Laptop - Dell Inspiron 5160 - 3.2GHz - 1GB RAM :: Desktop - Asus P5GD2-Deluxe Mobo - Pentium 4 2.8GHz CPU - 2 x 1GB RAM - 3 x 250GB Maxtor... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Mon, Sep 10 2007 10:41 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 441
    • Points 5,195
    Also check your maximum duration for captures.  if it is set to 6 hours, and you only have 3 hours, open ended captures will try to reserve 6 hours of space.
    MC 3.0! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Tue, Sep 11 2007 10:54 PM In reply to
    • JoeProcopio
    • New York City
    • Posts 310
    • Points 3,810
    thanks, i'll ask the editor what his setting were...
  • Tue, Apr 22 2008 4:20 PM In reply to
    • escheck
    • Joined on Wed, Apr 2 2008
    • Posts 4
    • Points 40
    Just wanted to chime in to say that adjusting maximum duration for captures is most definitely the solution.  I've come up against this a few times with our Unity and every time it points to this solution.
  • Thu, May 8 2008 11:37 PM In reply to
    I just started a project and after digitizing from a few different source tapes I started to get the same lame error message and I had plenty of drive space, etc. Where is this maxmun duration for captures setting? I went into capture settings to investigate but did not see. I'm using Media Composer Adrenaline v2.7.7
    The only thing that worked for me was to digitize the media as OMF Media instead of MXF media and the problem went away. Hooray!!! Hope that might help someone on this thing.
  • Wed, May 14 2008 7:05 PM In reply to
    • JoeProcopio
    • New York City
    • Posts 310
    • Points 3,810
    open your capture settings, there is a tab for .mxf media, that settings should be less than your total storage available, so if you have 2 hrs available, make sure that is less than 120 minutes...etc...and it is only for .mxf files, that is why .omf files work...but if you are like us, .mxf is a much better way of media management, causing the avid to automatically make new folders so you avoid the folder file count limitation that .omf has.
  • Thu, May 15 2008 2:18 PM In reply to
    • ceffoavid
    • Joined on Thu, Jan 17 2008
    • Posts 107
    • Points 1,215
    Hi Joe, just curious as what version of Unity you have and what type of clients?  MAC or PC clients?
    ACSR
    Media Composer, Symphony, DS, Unity
  • Thu, May 29 2008 2:16 PM In reply to
    • JoeProcopio
    • New York City
    • Posts 310
    • Points 3,810
     Unity 5.0 with 5 Media Composer Arenalines 2.8.3 now, 2.7.5 when problem occurred, and 2 Symphony Nitrii (plural of Nitris, hehe) 1.8.3, was 1.7.5
