Latest post Fri, Sep 21 2007 10:12 AM by nof. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Aug 15 2007 10:42 AM
    • nof
    • Joined on Wed, Aug 15 2007
    • Posts 3
    • Points 55
    Silver 4.02 SP2 >> Chrome XE 7.2
    Hello,
    we are in the process of upgrading to Chrome Xe from Silver 4.02.  With Silver we have external RAID, which we will connect to Chrome. Can I simply copy the projects folder and check that the external RAID on Chrome has the same letter as on Silver (F:)? The question is - are the files (project + data) compatible? If not - any ideas how to transfer the existing projects.
    Best regards
    sebastjan
  • Wed, Aug 15 2007 12:22 PM In reply to
    • Dean Athan
    • Melbourne, Australia
    • Posts 528
    • Points 6,440
    Re: Silver 4.02 SP2 >> Chrome XE 7.2
    sebastjan,
    I'm not a past Silver user so I can't answer this for certain. However, if you try this you will be able to determine if Liquid Chrome Xe 7.2 can or cannot convert the old project files.
    As well as connecting your external raid you also need to copy the Liquid 4.2 project files located on your c: drive into the Chrome Xe's system drive (e.g. in Liquid's project directory). After this try to open the old project files with Xe to determine if they can be converted or not.
    Please backup everything you may need before trying any of the above.
    Let us know how you go.
    Dean Athan
  • Wed, Aug 15 2007 10:02 PM In reply to
    • John Godwin
    • Atlanta
    • Posts 145
    • Points 1,820
    I've upgraded some old silver projects to chrome. The short answer is sometimes it works, sometimes it doesn't. It especially appears to have trouble with various effects filters, although if I remember correctly you should get your clips and such, but may have to reassociate the media or redigitize it.
    LE7 sp2: 2 P4 3.0G, 2gb ram, X600 PCI-e Dual Video, 1G 333MHz DDR, XP Pro [view my complete system specs]
    Best, John Liquid 7.2, P4 3.0Gx2, 2gb ram, ATI Radeon X1900XT Video, 1G 333MHz DDR, XP Pro Chrome: Liquid 7.2, Xeon 3.2Gx2, 2gb ram, ATI Radeon X1600XT Video, 256 DDR2, XP Pro
  • Fri, Aug 17 2007 3:59 AM In reply to
    • Westa
    • Joined on Mon, Oct 23 2006
    • Brisbane Australia
    • Posts 75
    • Points 970
    Its really a bit of a lucky dip.
    In theory Chrome will convert the project across to the new format ... but there are some area where things can still go wrong.
    You may need to manually relink some clips - never worked out the exact reasons or differences.
    Westa
    DELL 710 x 2 Core 2 Duo 6600 2 Gig Ram ATI 1950Pro 512 meg LVD SCSI 3 876mb RAID 5 Render Farm / Server 1tb via 1gig Ethernet [view my complete system specs]
    Westa - australia
  • Mon, Aug 20 2007 2:31 AM In reply to
    • msusman
    • Houston Texas
    • Posts 20
    • Points 210
    It should work pretty well.  Just last week we ported a Liquid 5.6 project across our lan to the Xe workstation.  All the effects, titles and imported files worked as expected.  We had to be careful to create drives and paths that matched the old project. Now this was not a highly complex project. But I would think 4.0 to 7.2 would be easier than from 5.6 as 5.6 relied mostly on the Targa 3000 for hardware effects. 4.02 was CPU so it should be pretty straight forward.   Good luck. Let us know how it turns out.
    - Liquid Chrome Xe 7.2 - Liquid Chrome 5.6 - Liquid 7.2 - 601/Silver 5.6 with InTime, Dual PIII 550, 512 megs [view my complete system specs]
    Lov'n Liquid since v.1 (fka 601) - Liquid Chrome Xe 7.2 (HP XW8400) - Liquid Chrome 5.6 (Targa 3000) - Liquid 7.2 Pro (HP XW8000, dual 2.8 xeon) - Liquide 7.2 notebook
  • Fri, Sep 21 2007 10:12 AM In reply to
    • nof
    • Posts 3
    • Points 55
    well - it worked :)
    Chrome had no problem opening Silver V4 projects. However it did "freeze" in the final stage of importing/converting projects.. but when I restarted Chrome project was there. Great :)
    regards
    s.
