Latest post Tue, Jul 31 2007 10:49 PM by NP. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Jul 24 2007 1:02 AM
    • GinoEdit
    • Joined on Sun, Jul 30 2006
    • Charleston, SC
    • Posts 30
    • Points 470
    Adjusting Audio Levels
    Few questions...
    I am having trouble adjusting the audio levels.  I can open the audio mixer and bring the level down for a selected track, but it brings the entire clip down to the same level.  How do I make multiple marks on a selected track and pull down the sound so as to fade up/down?
    Another problem I'm having is setting my ins/outs on the timeline and setting an in-point on my source.  But when I try to click over-write, I get an error message saying Sync Match is on??
    Gino
    Dell Inspiron E1505 intel duo core processor at 1.66 GHz, 1 GB RAM memory. Avid Liquid v7.1. [view my complete system specs]
  • Tue, Jul 24 2007 1:49 AM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,293
    • Points 59,670
    • BlogAuthor
      Moderator: Avid Free DV
      Moderator: Avid Xpress DV PC
      Moderator: Avid Xpress Studio
    Re: Adjusting Audio Levels
    Use rubberbanding... it will enable you to basically draw a curve (with edit nodes -- i.e. key framing) which corresponds to the audio levels... you can do manual fades, etc., and VERY precise control of audio levels.
    You can turn Sync Lock on and off... check your online help file.
    Mac Pro. QHD Ultra wide, thunderbolt LG monitor, MC 2018.3.0. Pro Tools 11 HD (Mbox 3 Pro), iPad Pro 12.9". 17" Macbook Pro i7. Dell Precision... [view my complete system specs]
  • Tue, Jul 24 2007 1:53 AM In reply to
    • GinoEdit
    • Charleston, SC
    • Posts 30
    • Points 470
    Where do I find rubberbanding and what controls do I use to create this option on the timeline?
    Thanks!
  • Tue, Jul 24 2007 2:00 AM In reply to
    • MrFixIt
    • Joined on Mon, Apr 16 2007
    • Posts 23
    • Points 265
    GinoEdit:
    Few questions...
    Gino
    What you're observing with audio levels is exactly as it is designed to work. To change audio level in specific parts of an audio track you need to use audio gain automation
    To view the audio level in the timeline, select Clip Gain in the Timeline fast menu (the hamburger button). If the audio track is too small to see use the CTRL + L key combination repeatedly (CTRL + K reduces size).
    Key frames can now be added to allow manual adjustment of the volume. Move the timeline indicator to the start of the clip you want to adjust and press the 'N' on your keyboard. This will place a small pink marker to indicate a keyframe has been set. Moving the timeline indicator to the end of the clip and adding another keyframe will allow you to drag the audio level up and down for the entire clip. Placing further keyframes within the clip will then allow you to adjust the level around the position of the keyframe.
    If you get the Sync Match warning it is because you have Sync Lock selected on your time line and what you're trying to do will mean the audio will be out of sync in relation to the original timeline clip and the clip you're overwriting with. If you really want to do this, and in many cases you would, switch-off the Sync Lock on the track you want to use. The Sync Lock is the button/icon to the left of the track selectors.
  • Tue, Jul 24 2007 2:08 AM In reply to
    • Adman
    • Posts 5,293
    • Points 59,670
    • BlogAuthor
    Sorry... I was booting my  Media Composer to offer more specifics (so I wasn't going from memory) and my system crashed.
    Looks like Mr. Fixit beat me to it.
    There is a good explanation of rubberbanding in the online help... but you can't search on the term. Search for Audio, then look under "adjusting volume in Timeline." It is under "Using Automation Gain and Pan."
  • Tue, Jul 24 2007 2:10 AM In reply to
    • Adman
    • Posts 5,293
    • Points 59,670
    • BlogAuthor
    Oh... and fwiw, look up Sync, then "Sync Lock button (Track Selector panel) for a diagram of the Sync Lock button location in the timeline.
  • Tue, Jul 24 2007 2:11 AM In reply to
    • GinoEdit
    • Charleston, SC
    • Posts 30
    • Points 470
    Thanks for the great help FixIt... I will try these suggestions tomorrow at work.  My piece is supposed to air Friday and I'm new to the Adrenaline.  I worked on Newscutter at my previous station and this has way more bells and whistles so I'm adjusting to the different settings/tools/menus/etc.
  • Tue, Jul 24 2007 2:38 AM In reply to
    GinoEdit:
    Keyframing/Rubberbanding, Audio Automation Gain, etc have all been staples in the Avid product line for a long time.  The Audio Settings are and have been in the same places for as long as I can remember.  I know that it can be intimidating, but the fact that you're now on an Adrenaline doesn't mean "boo" with regards to basic functionality like Audio Gain adjustment.  Read through the manual.
  • Tue, Jul 31 2007 6:31 PM In reply to
    • grinner
    • stl
    • Posts 60
    • Points 910
    tre is always more than one way to mlk a goat.
    I don't use rubberbanding because I like to kee my tracks itty bitty and I like to utilize my ram for babying adrenaline. I just add edits and dissolves and use the mixer. Much much quicker and precise for me.
  • Tue, Jul 31 2007 6:37 PM In reply to
    • DRW
    • Joined on Wed, Nov 9 2005
    • TORONTO
    • Posts 571
    • Points 6,950
    Quicker yes, precise - not so much. IMHO the best way is to use a MIDI interface controller and actually mix the show live, that way you can get precise, natural fades, in real time.
    .02
    =DRW
    iMac, 27", 3.4GHz i5, 24 GB RAM, Radeon Pro 570 [view my complete system specs]
    1-800-IMRENDERING
  • Tue, Jul 31 2007 7:07 PM In reply to
    DRW:
    IMHO the best way is to use a MIDI interface controller and actually mix the show live, that way you can get precise, natural fades, in real time. .02 =DRW
    Sounds like a shakey (Rocky) option to me. What happens when your fader hand flutters with antici............pation!
  • Tue, Jul 31 2007 7:17 PM In reply to
    • DRW
    • TORONTO
    • Posts 571
    • Points 6,950
    Not possible. I had my hands replaced with robotic armatures last year.
    =DRW
    1-800-IMRENDERING
  • Tue, Jul 31 2007 8:40 PM In reply to
    • grinner
    • stl
    • Posts 60
    • Points 910
    I can see how that would be as precise as typing in a numeric value but for those of us who are not robotic... the mixer may be the way to go.
  • Tue, Jul 31 2007 10:49 PM In reply to
    • NP
    • Edmonton
    • Posts 51
    • Points 560
       The cut, adjust and dissolve method is better for a work in progress as you can trim the dissolves rather then losing nodes when you trim.
